Reply 20 of 25, by Guest
Same results with NVIDIA drivers. No difference with different renderes.
I used 'top' to measure. X = 90%, dosbox = 9% When I skip framerates
X reduces CPU usage.
I feel that this could be a kernel 2.6 problem. Older dosbox used to work
fine on my RH9 (kernel 2.4).
>Are you using the latest video and sound drivers on the Linux version?
>Have you tried different output renderers and sound sampling rates?
>Have you tried disabling sound altogether? Are you testing with the exact
>same DOSBox configuration on Linux and Windows, or are you changing
>other settings besides cycles?
>Also, what program are you using to monitor "resource" usage in Linux?
>Does it actually say that your CPU is 0% idle?
