Reply 520 of 659, by candle_86
- l33t
wrote:wrote:Athlon 64 X2 6000 @ 14x230 3220mhz ASUS M2N-SLI - 8gb 920 DDR2 6-6-6-18 - 7900GTX 92.91 - XP Pro SP3 - SB Audigy 190.5 […]
190.5So it seems I'm not maxing out my 7900GTX SLI at 10x7 then again i tested it and at 12x10 i get identical FPS so I guess i knew 🤣
Thanks for testing that! 😀
You've gotta be close to maxing out a single card, since you gain 11 fps from enabling SLI. On my Opteron, adding a second 8800GTS didn't improve performance at all; in fact I lost 1.4 fps.
Well I can test that I think. I have a Celeron Haswell with DDR3 1333, it should be able to push the 7900GTX has fast as possible I think.
