Commander Keen 4 & 5: Composite CGA Editions
Schedules and announcements about program releases.
Re: Commander Keen 4 - Composite CGA Edition
Postby bjt » 2016-5-23 @ 19:44
My LCD monitor/TV doesn't look nearly as nice as Keropi's CRT but this is awesome nonetheless!
User avatar
bjt
Postby keropi » 2016-5-23 @ 20:02
^ there might be a way soon-ish to make a PAL 1084S-P1 ntsc compatible - changing the PAL decoder to the NTSC counterpart and adding/replacing some passive components. It's been under investigation from a more knowledgeable person, if it is a success I'll make a detailed post about the conversion. :)
This would allow us to have a single monitor for TTL rgb, ntsc compatible composite/svhs inputs and a nice 15khz analog rgb monitor :D
User avatar
keropi
Postby bjt » 2016-5-23 @ 20:15
That would be cool. I have a Tandy badged CM8833 (SCART only), hopefully it's similar enough to make the same mod.
User avatar
bjt
Postby VileRancour » 2016-5-24 @ 06:41
@NY00123: to complement your PKCF post, I'll do a blog entry with some more details on the code... might help source/binary modders, I guess. Note that I didn't repack CKPATCH, only removed the existing UPX compression (I believe that UPX should have a 8088-friendly depacker option, but I haven't tested that yet).
@bjt: interesting -- that's a hXc setup indeed :D Is your CGA card a 'new-style' one, by the way? Might explain the extra saturation, although I guess that could just be the camera.
@keropi:
keropi wrote:on a V20/10mhz the game is very playable
Nice to know! Was wondering about the minimum CPU requirements for acceptable performance (the 'typical' system that ran this game would've been a high-end 286/low-end 386SX, but those systems are unlikely to have CGA cards, let alone true IBM ones for correct colors).
web  /   blog   /   tube
User avatar
VileRancour
Postby bjt » 2016-5-24 @ 07:56
VileRancour wrote:Is your CGA card a 'new-style' one, by the way? Might explain the extra saturation, although I guess that could just be the camera
Yep, new style CGA. I have a V20 in my 5160 but it's too slow for this game really.
User avatar
bjt
Postby SquallStrife » 2016-5-24 @ 09:52
Fun fact, the game might run on an 8088, but the self-extractors crash (K4C1-ASP.EXE and K4C2-ASP.EXE). lol
[retro swim] | Link | Release Thread
Twice-weekly silliness on Twitch!! http://www.twitch.tv/RetroSwim (8:30PM Fri+Mon AEST)
User avatar
SquallStrife
Postby elianda » 2016-5-24 @ 10:25
Does this composite version works as well with the video out from EGA cards?
(like this one http://www.retronn.de/imports/hwgal/hw_genoa_ega.html)
Youtube Channel
User avatar
elianda
Postby SquallStrife » 2016-5-24 @ 10:32
I capped* some gameplay footage, including toggling between RGBI and Composite.
https://www.youtube.com/watch?v=mVqXdndLIgw
* Shot my PVM monitor with my phone camera!
User avatar
SquallStrife
Postby bjt » 2016-5-24 @ 12:26
elianda wrote:Does this composite version works as well with the video out from EGA cards?
No, unless you connect a board to the feature connector to create an NTSC composite signal.
Could be a nice project for someone.
User avatar
bjt
Postby carlostex » 2016-5-24 @ 13:59
VileRancour wrote:
@keropi:
I wish i could try it on my 12MHz V20 but i don't have a real IBM CGA card.
Anyway VileR this is awesome. Thank you sir!
User avatar
carlostex
Postby keropi » 2016-5-24 @ 14:29
^ you really need to invest in one if you are serious about xt+cga stuff Carlos , there is no alternative sadly
SquallStrife 's video inspired me to make a quick video too, quality is not that great but you get to see how it performs with a 10mhz V20 :)
https://www.youtube.com/watch?v=ZAOIdin3I4U
User avatar
keropi
Postby Scali » 2016-5-24 @ 14:40
I hope to do some captures of CGA clones with composite over the weekend. An ATi Small Wonder and a Paradise PVC4.
Scali
Postby NY00123 » 2016-5-24 @ 18:38
VileRancour wrote:@NY00123: to complement your PKCF post, I'll do a blog entry with some more details on the code... might help source/binary modders, I guess. Note that I didn't repack CKPATCH, only removed the existing UPX compression (I believe that UPX should have a 8088-friendly depacker option, but I haven't tested that yet).
Good to see you intend to write these details. Here is the PCKF topic for reference: http://www.pckf.com/viewtopic.php?t=3656
Regarding UPX, I've mistakenly assumed that you've used such an option of UPX. My copy of UPX appears to have an --8086 option, but since it's not exactly "8088", I don't know for sure if it'll be useful.
To the ones who wonder, I'll quick add that in addition to CKPatch, ModId (the Windows EXE currently available from https://github.com/owenmpierce/modId) was used for importing the graphics. While the patch takes advantage of CGA mode 6 (640x200x2colors), rather than mode 4 (320x200x4 colors) as usual, the graphics' layouts are more-or-less the same.
NY00123
Postby SquallStrife » 2016-5-24 @ 23:35
keropi wrote:^ you really need to invest in one if you are serious about xt+cga stuff Carlos , there is no alternative sadly
Quite the difference!
From what I understand, the EGA/VGA version should run a lot better, as the CGA version is quite CPU intensive.
User avatar
SquallStrife
Postby VileRancour » 2016-5-25 @ 06:51
SquallStrife wrote:I capped* some gameplay footage, including toggling between RGBI and Composite.
Heh, kind of surprising - the PVM preserves the 'stripy' appearance of the RGB picture even in composite mode, which probably means that its luma decoding bandwidth covers higher frequencies than usual. Guess I didn't consider such high-end equipment!
Curiously the game looks quite a bit faster than in Trixter's video... that *is* a stock 5150, though?
and potentially get 65,536 composite colors from EGA's 640x200x16 mode... hmm. :D
keropi wrote:SquallStrife 's video inspired me to make a quick video too, quality is not that great but you get to see how it performs with a 10mhz V20 :)
Hey, that actually looks like optimal speed, or close enough anyway. Cool. :)
NY00123 wrote:Regarding UPX, I've mistakenly assumed that you've used such an option of UPX. My copy of UPX appears to have an --8086 option, but since it's not exactly "8088", I don't know for sure if it'll be useful.
Just standard terminology (the 8088 will run any 8086 code), so yeah, that's the option to use.
web  /   blog   /   tube
User avatar
VileRancour
Postby Jo22 » 2016-5-25 @ 07:30
Awesome work! Congratulations on a job well done.
I've tested this patch on my "CGA" card and I'm glad to say it works. :-D
Scrolling is fine so far, just the colours are a bit funny, not to say funky.
But maybe that's either because of my setup or Billy hasn't seen a doctor in a while. :-)
User avatar
Jo22
Postby Scali » 2016-5-25 @ 08:25
Yes, to elaborate on that: The 8088 is basically an '8086SX' in the same sense as the 80386SX.
It is the same CPU, on a smaller bus. So for applications there is no difference between an 8088 and 8086. The 8086 can just be a bit faster because it has a 16-bit bus, where the 8088 has an 8-bit bus.
So in programming parlance people generally refer to the '8086 instructionset', rather than 8088. But they are both the same.
Scali
Postby VileRancour » 2016-5-25 @ 18:16
Jo22 wrote:Awesome work! Congratulations on a job well done.
Yep, that's about what I expected a non-IBM card to do. I'm actually curious to know just what this card is -- could be an interesting data point for future experiments (hue is about 50° off), plus that text mode font could be a nice addition to my oldskool PC font pack thing...
web  /   blog   /   tube
User avatar
VileRancour
Postby SquallStrife » 2016-5-26 @ 00:02
Stock except for the Lo-tech 1MB RAM board!
User avatar
SquallStrife
Postby Jo22 » 2016-5-26 @ 10:30
Whew! I'm glad you're not angry about my pictures.
I've been a huge Keen4 fan and just had to test this awesome patch myself on the hardware I have!
The pictures were taken from a cheap LCD monitor, which claims to be multi standard (PAL/NTSC/SECAM).
I wished I still had my Commodore 1702 monitor, so I could have provided you with higher quality pictures.
Or any other old school monitor with a comb filter..
My setup:
386DX-40 with turbo brake enabled, caches disabled.
Epson Model Q205A ("CGA" card with mono/colour switch)
Philips 15PF4121
Here's a picture of my CGA wanna-be and a dump from that crystal memory.
I hope they're useful. I've tried to capture the resistors as best as I could.
epson_cga.zip
Epson Model Q205A control program/font
(3.92 KiB) Downloaded 23 times
Epson Model Q205A graphics card
User avatar
Jo22
PreviousNext
Return to Release Announcements
Who is online
Users browsing this forum: No registered users and 3 guests
