I can't always boot Windows 3.1 on my 80486SX2 Olivetti PC
First post, by Elia1995
Hello, I'm having this odd issue since yesterday, I can boot up Windows 3.1 just fine after a bunch of retries, it works fine if first I launch Doom 2 for about 10 minutes and then I try to launch Windows 3.1, but I can never boot it up just as I turn on the PC.
I get this error message if I try to launch it immediately:
But it runs fine after a bunch of retries and with launching Doom 2 before.
Currently assembled vintage computers I own: 11
Most important ones:
A "modded" Olivetti M4 434 S (currently broken).
An Epson El Plus 386DX running MS-DOS 6.22 (currently broken).
Celeron Coppermine 1.10GHz on an M754LMRTP motherboard
Reply 1 of 66, by dr_st
Fix the file allocation table on drive C.
I used to use Norton Disk Doctor back then. I am sure there are other alternatives. IIRC, the built-in CHKDSK of DOS6 still does not do it.
Reply 2 of 66, by Elia1995
I have MS-DOS 7.10 in there.
Reply 4 of 66, by Elia1995
Ok, I'm letting Scandisk checking the sectors, let's hope it doesn't find any bad sector...
Damn, it's really slow...
EDIT:
Ah well...
22dbc9f293a14bc69645a5e6f5d061db.png 😢
Look how Scandisk trolls me:
Reply 5 of 66, by dr_st
This partition is not formatted FAT32 by accident, is it? (not even sure how Win3.x would behave if you tried launching it from such a partition...)
Reply 6 of 66, by Elia1995
The odd thing is that Windows 3.1 always works if I first launch Doom 2 (even just launch it and then close it).
As long as I launch Doom 2, I can boot Windows 3.1 with the command, it's nonsense.
Reply 7 of 66, by matze79
Maybe some fault with Protectmode Switching ?
can you try starting with win /s
Reply 8 of 66, by Elia1995
Reply 10 of 66, by Elia1995
I only have MS-DOS 7.10 and Windows 3.1 in it, where should I place the extracted files from this archive ?
Reply 11 of 66, by matze79
ok then this will fix the issue, just read the readme included.
Reply 12 of 66, by Sammy
I have the same error, but only when win3.11 was running , exit, and try to run again.
I think, it has something to do with the network too.
Ah, i remember......
Do you have smartdrv in config.sys or autoexec.bat?
Then remove it, or REM it out.
What version of himem.sys and emm386 are you using? From Windows3.11/Dos 6.22. or from Dos7.10 ?
I think w3xstart is already used, because win3.x is starting (or trying).
When io.sys is not Patched, there is another error.
Reply 13 of 66, by Elia1995
Hmmm... actually after I manage to get into Windows 3.x and try to enter again, it does that error aswell...
I dunno what version of himem and emm386 I'm using, probably it's dos 7.10's one.
Anyway, I got this error while trying to patch io.sys with that software:
Reply 14 of 66, by Jo22
Did you try chkdsk c: /f from a bootable floppy (DOS 5/6) ?
Despite beeing an older utiliy, this one can sometimes fix errors Scandisk can't.
Should work with a pure FAT16 drive, at least. Don't know how it behaves on VFAT.
I also remember there was an unlock/lock command in DOS 7.0.
I've no idea what it was for, but I think I needed it for defrag a long time ago..
Can't find any information on the web, though.
Reply 15 of 66, by Elia1995
I believe lock and unlock set the permissions on that drive so you can write or read only.
Reply 16 of 66, by Jo22
Ah, okay then. Was a long time ago I used this command the last time (ca. 1996-97). 😊
Reply 17 of 66, by Elia1995
Sammy wrote:
I have the same error, but only when win3.11 was running , exit, and try to run again. I think, it has something to do with the […]
the only smartdrv I found was in autoexec.bat and it was already REM'd.
Reply 18 of 66, by Jo22
Uhm, by the way, are you people running Windows 3.10, Windows 3.11, Windows for Workgroups 3.10 or Windows for Workgroups 3.11 ?
For original Windows 3.1 was an update available for free.
Reply 19 of 66, by Elia1995
For me it's just "Windows 3.1"
