First post, by mbbrutman
System specifications:
- NEC V20 CPU running at 4.77Mhz
- 736KB RAM (64KB on the motherboard, 64KB on an internal card, and the rest on the jrIDE sidecar)
- QumeTrak 142 5.25 double density floppy drive
- Bootable IDE interface (jrIDE sidecar)
- 20GB Maxtor IDE hard drive (up to 8GB usable)
- IBM PC 5150 keyboard connected via a Racore keyboard adapter
- Two joysticks
- Parallel port sidecar modified to be bi-directional
- Xircom PE3-10BT Ethernet adapter on the parallel port
- Additional power via a power sidecar
- Dallas 1216E real-time clock
- OS: Dual boot to either IBM PC DOS 3.3 or IBM PC DOS 5.02
- On the screen: mTCP IRCjr IRC client connected to slashnet.org
Additional peripherals (not attached at the moment):
- Iomega Zip 100 drive w/ PalmZip drivers
- Second bi-directional parallel port sidecar
- Speech adapter sidecar
- Microsolutions Backpack 3.5" floppy drive
- Bridge-888 parallel port SCSI adapter
- IBM 2x SCSI CD-ROM
- 500MB Fujitsu SCSI hard drive
- Western Digital 8003 Ethernet card via an ISA bus adapter
- Microsoft serial mouse
