I can't always boot Windows 3.1 on my 80486SX2 Olivetti PC
Reply 60 of 66, by Jo22
Oh well.. This is getting somewhat frustrating. 🙁
So you can't boot from a floppy, you can't boot from CD and your HDD has a screwed installation of DOS ?
Maybe someone casted a spell ? Do you have any wizards in you neighborhoud ?
Is your PC located next to a window ?
I think it's best to make a backup of your batch files and wipe the disk.
But before you do, please let me ask you: Can you transfer files somehow at all ?
Via a floppy, a terminal program or a ZIP drive ? Or can you hook up your drive to an USB-IDE adapter ?
And does the floppy drive work properly or are there any read/write errors (Checkit! can check it) ?
Or do you have at least a copy of Windows 95 (Win95b/c update disc) ?
If so, this *could* fix all you problems. If you install Win95, you would have a proper DOS 7.x and
you could also transfer files more easily (TCP/IP or direct cable connection).
Windows 98 would also work, but it requires more disk space and you would have to start setup with the /nm switch.
But these are just ideas. I won't take any responsibility for data loss or green slime coming out of your PC.. 😉
Reply 61 of 66, by Elia1995
So, I installed this Dr. Dos 7.03 system, now when I boot I have a boot menu with "Standard" (DOS 7.10, which doesn't boot at all anymore, now it's missing himem.sys due to Dr. Dos's installation) and Dr. Dos 7.03 which works like a charm.
It automatically fixed the issue I had with the sound card not being detected anymore (I haven't checked if it still does that "volume" problem I talked about in my other thread), I entered into Windows 3.1, quit and re-entered and worked...
Now if only I could remove that pointless boot menu at startup and having Dr. Dos 7.03 as automatic boot... but whatever, even though I can't, it's not a problem...
let's see how long it will keep working... ah yes, and I didn't even format...
EDIT: Yep, the sound issue is still present (it works, the card now is being detected, but it still "farts" as I mentioned in the other thread), the master volume gets automatically pushed to maximum after some games, in short.
Currently assembled vintage computers I own: 11
Most important ones:
A "modded" Olivetti M4 434 S (currently broken).
An Epson El Plus 386DX running MS-DOS 6.22 (currently broken).
Celeron Coppermine 1.10GHz on an M754LMRTP motherboard
Reply 62 of 66, by kixs
Not sure what are you doing... but DOS problems should be solved within minutes as it's a very simple system.
After random games or after a particular game?
Reply 63 of 66, by Elia1995
So far, I've noticed it with Epic Pinball, Raptor and Jill of the Jungle.
It happens as I run the games, the volume explodes, check out my related thread where I've also posted a video.
Reply 64 of 66, by Jorpho
I'd never used DR-DOS before, but Googling around suggests that if you attempt to run LOADER.COM on the command line (or possibly LOADER /? or HELP LOADER), then you might get some answers.
Reply 65 of 66, by matze79
EDIT: Error..
Reply 66 of 66, by Elia1995
Why would I want to low-level format the hardisk now that I got Windows 3.1 to work fine ?
