First post, by candle_86
So this the build I'm working on, not all parts are in yet.
Parts list
Pentium 3 800 100mhz slot-1
SOYO 6BA+IV
Kingston PC-133 @ 100 2-2-2-5 3x128 384MB
Dell Geforce2 Ultra
VIA USB2.0 Riser*
Maxtor Promise ATA133*
80GB Seagate 7200.7 IDE
Sony DVD-RW IDE
Sound Blaster Live! 5.1
450W Sun Cheer PSU Recapped
Generic ATX case (want better case)
Windows 98SE
Case Badges*
* not arrived yet
How's it look?
Reply 3 of 16, by candle_86
decided to paint the case after sanding it, and use hot glue to hold the front panel on (the pastic clips on one side broke off, but the glue working great.
1.33 MiB
Reply 4 of 16, by candle_86
Promise Ultra 133 TX2 and VIA USB 2.0 came in.
Question is there anyway to hook a front panel USB up to the internal USB port on the card?
Nm found this
http://www.moddiy.com/products/USB-9%252dPin- … dA-Adaptor.html
Might order it next month
Reply 5 of 16, by candle_86
Ok its complete
SOYO 6BA+ IV
Pentium 3 800 100mhz FSB
3x128mb PC-133 Kingston @ 100mhz 2-2-2-5
BFG FX 5900 XT (couldn't leave it to languish in a box)
Maxtor Promise ATA133 TX2
VIA USB 2.0 Expansion Card
Trendnet 1gb Network Card
Western Digital Cavler 200BB (20gb)
Western Digital Cavier 800BB (80gb)
Western Digitial Cavier 100AA (10gb)
Maxtor 6 20gb
Microsoft Sidewinder Precision 2
Gravis Multi Port with Gravis Grip Pad
Reply 6 of 16, by Tetrium
I understand you don't want to have a FX5900 laying around doing nothing for no good reason, but it might be more fun to build a new rig around it 😀.
And why so many harddrives?
My retro rigs (old topic)
Report spammers here!
Reply 8 of 16, by candle_86
Limit of 3 computers in the house according to my wife, the other retro has a 500gb and a 250gb SATA, so I put all my IDE drives into this one because i can 😜
Reply 9 of 16, by Tetrium
🤣, approved! 😁
Reply 11 of 16, by Tetrium
candle_86 wrote:
Plus how many of us would have done back in 99/2000? I know I used every drive I could get my hands on
I don't think that I did this, mostly because harddrives were one of the few things I never had enough of.
Reply 12 of 16, by nforce4max
That makes me wonder about building some sort of combo rig or something like that where there is multiple builds in big one case 😉
She only said three but didn't say how big or small 😈
Reply 13 of 16, by melbar
Nice build!!!
I like your 440BX board. Seems like it's a good choice according to RAM-slots / PCI-/ISA slots and IDE ports...
anandtech says about something:
"The location of the power connector is less than ideal. As it is, the ATX power cable has to snake around the CPU to reach its destination,..."
Can't see in between CPU and PSU but it seems you have solved it in a good way!
From my point of view, the FX5900XT is too overpowered for the "little" PIII. I know, you've already said about the (your) limit of 3 PC's.... I think the Ultra is also a good choice.
I have also a PIII, but a S370 with 866MHz. Up to know it's not finally built and i have also the choice between several cards.
(GF2-MX400 or GF2-GTS or GF2-Ti or GF3-Ti200...).
#1 K6-2/500, #2 Athlon1200, #3 Celeron1000A, #4 A64-3700, #5 P4HT-3200, #6 P4-2800, #7 Am486DX2-66
Reply 14 of 16, by candle_86
melbar wrote:
Nice build!!! […]
Nice build!!!
The FX is only temp, the ultra will go back in once my banshee arrives. I also snaked the 20pin into a hole under the psu in the case. It still snakes a bit but I got used to dealing with that kind of placement in 2002/2003 with Athlon XP ecs boards 🤣
Reply 15 of 16, by Rhuwyn
At one time I think I had like 6 hard drives in my late Socket A system. It was a motly assortment of ATA100/133 and early SATA not a single drive was the same speed or capacity. I had a 500GB IDE drive in it that now sites in a Modded Original Xbox 😀.
Reply 16 of 16, by clueless1
Yep, did that too. It seemed as if the tower would twist slightly every time I powered it on from the combined torque of all the drive motors spinning up at the same time.
