First post, by dosdude82
Hello 😀 I am having trouble installing and running WWF In Your House for DOS. I am using D Fend Reloaded which comes with DOSBOX 0.74.
My problem occurs when I install the game. The progress bar or percentage goes up normally but at some point the installation crashes and kicks me out of DOSBOX and brings me back to the D FEND reloaded GUI.
I should point out that I am using the Original CD for this install and mounting it within D FEND reloaded.
The core and cpu cycles were set to auto.
Sound is soundblaster
extended and expanded memory Is enabled
memory size is 16 Megabytes
I did try using different CPU core choices too to not effect.
I am running this on a LENOVO Core i5 2.4 GHZ laptop with 8 gigs of RAM and Windows 7 if that helps.
Thanks for any help with this matter.
Sincerely,
dosdude82
