First post, by lucky7456969
- Oldbie
When I ran the command netx332p /PS=SERVER01
I got shell-332-21
I dig out a bit in the net,
I found that novell uses ETHERNET FRAME 802.3
But my novell server is using ETHERNET FRAME 802.2
I don't know why
ETHERNET FRAME 802.3 is for Novell servers
802.2 is just LLC frames
I just didn't know why.....
lsl.com is okay
ne2000.com is okay
ipxodx.com is okay
netx/netx332p aren't.
It just cannot find the server
I am using TAP tunnels, I bridge everything with the wifi system
and giving them each one a MAC address (different than the virtual card ones from the emulators)
When I ping from the dosbox into the novell server which sitting on some other ip
my main host responds, gateway responds, but not the novell server...
NET.cfg
Link Driver NE2000PORT 300INT 9FRAME Ethernet_802.2
dosbox.conf
ipx=truene2000=truenicbase=300nicirq=9macaddr=AC:DE:48:88:99:AArealnic=[my tap tunnel]
Could anyone please show me how to connect from the dosbox to the novell server which was installed on qemu.
And the client is dosbox ykhwong build with ipx turned on (the little switch in the .conf) file...
Thanks
Jack
