First post, by superfury
According to the Bochs' ioports.lst, there's a "TIMER.COM v1.2", which is the first RTC used in the IBM PC XT. Anyone knows where this program can be found?
UniPCemu Git repository
Reply 2 of 3, by superfury
Currently have implemented it as an alternative to the usual CMOS in my emulation. After some fixing, it now displays the correct system time. For some reason, it refuses to update the clock(using the /S option?)?
Reply 3 of 3, by superfury
I've implemented some kind of timings system, based on Unix Timerstamp(with added precision for microseconds) on top of my existing CMOS emulation(which now also handles the TIMER.COM v1.2 application):
https://bitbucket.org/superfury/x86emu/src/8d … MOS.c?at=master
Anyone can tell me what's going wrong here? When I try to set the time to 1-1-2000 at 0:00AM it's setting strange Date/Time values, according to the logging?
00:00:52:15.02824: Updating register 04=00
00:00:52:15.03308: Setting time: 2016-0-6 24:0:9.000047
00:00:52:15.03316: Old divergeance: 00000000.00000000
00:00:52:15.03320: New divergeance: -0001070.-0000001
00:00:52:15.03456: Updating register 02=00
00:00:52:15.03464: Setting time: 2016-0-6 24:17:0.000047
00:00:52:15.03472: Old divergeance: -0001070.-0000001
00:00:52:15.03480: New divergeance: -0000540.-0000001
00:00:58:42.01064: Updating register 08=01
00:00:58:42.01076: Setting time: 2016-0-1 24:17:9.000053
00:00:58:42.01084: Old divergeance: -0000540.-0000001
00:00:58:42.01092: New divergeance: -0000153.-0000001
00:00:58:42.01236: Updating register 07=01
00:00:58:42.01244: Setting time: 2016-0-1 1:17:9.000053
00:00:58:42.01252: Old divergeance: -0000153.-0000001
00:00:58:42.01260: New divergeance: 00001216.00000000
00:00:58:42.01424: Updating register 09=00
00:00:58:42.01432: Setting time: 2000-0-1 1:17:9.000053
00:00:58:42.01440: Old divergeance: 00001216.00000000
00:00:58:42.01448: New divergeance: 00000267.00000000
00:00:58:46.03624: Updating register 06=06
00:00:58:46.03636: Setting time: 2016-0-6 24:17:9.000053
00:00:58:46.03644: Old divergeance: 00000267.00000000
00:00:58:46.03652: New divergeance: 00000000.00000000
Anyone can tell me what I'm doing wrong here?
I have fixed some errors in conversion. The latest version can now be found at the repository:
https://bitbucket.org/superfury/x86emu/src/7d … MOS.c?at=master
Is this correct? What does Dosbox do to emulate this?
