Reply 20 of 38, by leileilol
Note: UT's Vertical sync option is actually reversed. You have to turn it on to turn it off 😀
and maybe OA 0.8.8 could be used as a benchmark. Not really plugging, i'm suggesting it as it's even more unoptimized and dirtier than Q3A itself with memory-hungry high-poly vertex morphed MD3s, textures that cause a 64MB card to thrash, abuse of multitexture, tons of texture switching, bloom, detail textures and the ever-so-fps-killing readpixel-on-every-frame lensflares that would bring a modern Vulkan-supporting card to their knees (even worse with SLI 😜)
Reply 21 of 38, by rick6
Yeah that's quite weird..and it got me sometimes in the past wondering what's going on. But i guess it was really turned off 😜
This was with the ATI HD 4670.
Also here's a screenshot of GPU-Z running this very card. Seems to be running at 16x?
I'm not really a PCI-E expert but after googling PCI-E 1.1 @ 16x can deliver 4GB\s and AGP 8X does 2.13GB\s, so PCI-E bandwidth shouldn't be the bottleneck here for the newer cards. Most likely it's a driver limitation under XP. or the CPU itself. Also the games weren't the best to test the newer cards i know, but these titles were the games i was really interested in. I bet Crysis would scale up like crazy on the newer cards like 3D mark 2003 did.
I'm still disappointed with Doom 3 here. Also with the performance of my AMD HD 7870, it felt strangulated in every situation but 3D Mark 2003
My 2001 gaming beast in all it's "Pentium 4 Williamate" Glory!
Reply 22 of 38, by leileilol
Another to mention that modern hardware sometimes doesn't report compiled vertex array extensions properly to idtech3 games like Q3 so it won't use the fastest drawing path automatically. You may need to force r_primitives 2 on every card you test
Reply 23 of 38, by kithylin
I've theorized myself that at a certain point video cards (and their drivers) as they got newer and newer.. both nvidia and ATI/AMD started progressively omitting optimizations in hardware and software for older DirectX-8 and further back games and the newer cards got progressively slower at older DirectX content, and instead the card manufacturers just started optimizing hardware and software for newer DirectX-9 and DX-10 instead. Almost to the point where in some titles, older cards almost match and sometimes surpass the newer bits.
It's just a theory to me but still.. I think it actually is a "thing", and I think we can sort of see it to some degree in the test results here.
And yeah, it looks like your testing board ran all the PCIE cards at "full speed" PCI-Express 1.1 16x, so that's not the issue with the newer cards, it's something else.
Reply 24 of 38, by brassicGamer
This is what i was wondering about. Is there some way we could scientifically prove it?
Reply 25 of 38, by archsan
I was going to comment earlier. There have been claims that Fermi gen cards are faster on DX9 games than later gen cards. Not sure where the supposed "bell curve" would peak on the Radeon side. Drivers must also play a big role on this.
If only we could 'standardize' on a testbed/platform and crowdsource all these GPU variations...
"Any sufficiently advanced technology is indistinguishable from magic."—Arthur C. Clarke
"No way. Installing the drivers on these things always gives me a headache."—Guybrush Threepwood (on cutting-edge voodoo technology)
Reply 26 of 38, by havli
xjas wrote:
Weird how the Radeon HD7870 is almost universally beaten or matched by the 3850 & 4670, except in the final 3DMark. Wonder what's going on there...
Slow CPU and different driver optimizations for each GPU architecture, which are most visible in CPU limited scenarios. 3dmark 03 is not that much limited... but still delivering only half the true performance of HD 7870.
Reply 27 of 38, by matze79
Just mssing dx9 optimisation ?
Texture of UT99 looks washed 😳
ah i remember S3 Metal, it has soo nice textures.
Reply 28 of 38, by candle_86
its a function of the card can brute force it without needing any optimizations in drivers. Also the reason older cards would score better than newer would also have to do with cpu overhead. Newer drivers and cards require more CPU overhead. And UT99 is CPU capped on newer cards, pretty much anything newer than say a Geforce FX would CPU bottleneck on UT.
Reply 29 of 38, by rick6
I've used S3 Metal in these tests, you can't notice that because i'm standing as much as i can against a wall and not all textures in UT are replaced with a higher S3 res. counterpart, because there isn't a S3TC version for that particular texture, as it is the case of deck16 textures were this printscreen was taken. Also i couldn't capture the games actual brightness on this printscreen because i was using opengl (i believe it was because of that), that's why it is so darkened.
The game looks astonishing in maps rich with S3TC textures like DM-Codex!
Reply 30 of 38, by swaaye
It's interesting to see where the Radeon 3450 fits in. It's 4 pixels per clock like GF3/4 but it has more than double the clock speed to save the day, and I guess the unified architecture is great for Doom3.
Reply 31 of 38, by agent_x007
"3DMark 01" = 3DMark01 SE ?
Did you ran 3DMark 2000 in compatibility mode ?
Reply 32 of 38, by kithylin
Also I'm curious what OS was used for these tests. If Windows XP 32-bit, then no compatibility mode is needed for 3dmark 2000, it just runs natively. I think.
Reply 33 of 38, by rick6
It was Windows XP 32-bit.
3D Mark 2001 was SE and i didn't ran 3D Mark 2000 in compatibility mode as i believe it was not necessary. Although the AMD HD 7870 wasn't able to run 3D Mark 2000 with or without compatibility mode.
Reply 34 of 38, by kithylin
http://www.outfoxed.net/3DMK2000patch4.zip replace your 3dmark2000.exe with this modified one (you'll need to rename it) and it's a modified / patched EXE file for 3dmark 2000 to allow it to run on newer video cards with higher video ram onboard. Works even on my 4GB GTX 770 card.
Reply 35 of 38, by rick6
I did it and it worked, but only when i changed the color depth, otherwise i would get a incredible amount of artifacts. It scored 15000+/-, really awkward 😁
Also i don't get why it's so hard to get a score above 20000\25000 on 3DMark 2000. Maybe it's a limitation of the formula it uses to calculate the score.
Reply 36 of 38, by kithylin
Nope, just need faster processors to go with it.
54,000 with some dual-gtx-260's I have and a i7-3770k @ 4.5 ghz: http://www.outfoxed.net/dual-gtx-260/3dMark%202000.jpg
I should re-do that test some day now that I have the cpu @ 4.8 ghz stable.
Reply 37 of 38, by leileilol
rick6 wrote:
Also i couldn't capture the games actual brightness on this printscreen because i was using opengl (i believe it was because of that), that's why it is so darkened.!
F9
Reply 38 of 38, by agent_x007
Didn't know my Core 2 Extreme is so fast : 33800 pkt. - LINK 😀
And that's with just 3,2GHz on one core, while using VIA chipset/x4 PCI-e speed and a single GPU mode 7900 GX2 graphics card.
