Is your pentium 3 faster then mine?
Reply 20 of 36, by Oldskoolmaniac
its because of the powerleap the asus p3v4x is picky on witch slotket adapters are used, i will be replacing it with an asus slotket as soon as i find one and this will also be coupled with it ---> http://www.ebay.com/itm/Tualatin-P-IIIs-1-4GH … Q0AAOxyRhBSxjSY
Motherboard Reviews The Motherboard Thread
Plastic parts looking nasty and yellow try this Deyellowing Plastic
Reply 21 of 36, by nforce4max
Jade Falcon wrote:
If I drop a newer video card and 1.4ghz in my piii setup it would be way faster. I'm sure I could get a 1.4piii around 1.6ghz ea […]
I'm sure I could get a 1.4piii around 1.6ghz easy. Maybe even 1.7ghz
Oh and thake a look at these!
http://valid.canardpc.com/show_oc.php?id=420005
2ghz p3 https://www.youtube.com/watch?v=Y8EMndSFFMk
Reply 23 of 36, by Oldskoolmaniac
Mine has better power supply
What power supply do you got?
you have not said motherboard. if it's p3v4x is should not be the fastest
My bad yea its an asus p3v4x.
Reply 25 of 36, by melbar
Oldskoolmaniac,
You write that you have a GF6800 Ultra, but the clocks in your screenshot are from a 6800 GT.
see: https://en.wikipedia.org/wiki/GeForce_6_series
6800 Ultra, Core (MHz): 400, Memory - effective(MHz): 1100
6800 GT, Core (MHz): 350, Memory - effective(MHz): 1000
#1 K6-2/500, #2 Athlon1200, #3 Celeron1000A, #4 A64-3700, #5 P4HT-3200, #6 P4-2800, #7 Am486DX2-66
Reply 26 of 36, by Oldskoolmaniac
yea it is a gt idk why i put ultra
Reply 27 of 36, by matze79
Does P3 Xeon count ?
Reply 28 of 36, by Oldskoolmaniac
well it is p3, sure ill allow it
Reply 29 of 36, by matze79
Hm i don't think it will compete with the 1,4Ghz, because it maxed out at 900Mhz with 2Mb Cache or 1Ghz with 256Kb.
if i find time i will make some Benchmarks 😀
Reply 30 of 36, by Oldskoolmaniac
is it a single slot?
I use to have a server with 4 p3 xeon's at 800mhz with 4gb of ram that thing was a beast.
Reply 31 of 36, by spiroyster
And which server was that? Sounds lurvly. Was it a HP by chance?
Reply 32 of 36, by Oldskoolmaniac
i believe it was dell power edge, it was so long ago when i had it.
Reply 33 of 36, by Oldskoolmaniac
So far my p3 rig is killing some of my p4 3.20ghz machines.
Reply 34 of 36, by Standard Def Steve
I have two PIII machines in regular use.
I made a thread about my Win98 machine a few months ago:
Bitchin'Fast! PC '99 - My DOS/Win98/Glide Rig
Haven't made a thread about my PIII-S/DDR rig yet, but it's coming up!
For now, here are some specs and a few pictures to whet your appetite:
Specs:
PIII-S 1400 @ 1575MHz/150FSB
2GB DDR @ 300MHz, 2-2-2-6
QDI Advance 12T motherboard (Apollo Pro 266T chipset)
eVGA GeForce 6800GT AGP @ 385/540
X-Fi ExtremeMusic
WD 500GB 7200RPM HDD, LG BD-ROM drive
GbE and SATA cards
Antec case and Zalman 400w PSU
XP-SP3
Since discovering that overclocked Tualatins can handle 720p H.264 without hardware acceleration, I've transcoded a few of my Blu-Ray movies to 720p so that I could play them on this machine. You know, because HD movies on a PIII is NEATO! 😁
I brought the machine upstairs and hooked it up to the plasma TV just to take these pictures:
"A little sign-in here, a touch of WiFi there..."
Reply 35 of 36, by exact
@foey: Wonderful combination of case, drives, sound card!
flickr
Reply 36 of 36, by Carlos S. M.
I do have a dual Tualatin IBM Server (IBM xSeries 220), but sadly it doesn't have an AGP slot. I even have a thread about it: Old IBM xSeries 220 Dual Tualatin Server
Specs:
2x Pentium III-S 1.4 Ghz
2 GB (2x 1 GB) RAM PC133R ECC
S3 Savage 4 Pro Integrated
Fujitsu 36 GB 10k rpm SCSI HDD
Creative Soundblaster Live 24 Bit
NEC USB 2.0 PCI Card
Windows Server 2003 SP2
The motherboard uses a quite non common chipset. ServerWorks ServerSet III LE
