Reply 220 of 2365, by archsan
- Oldbie
wrote:I have been debating whether I should get a 4K LED. It would only run @ 30HZ though. My W520 does not support 4K at 60HZ.
I'm currently running an LG UHD (not really "4K" which is 4096x2160!) IPS at 30Hz with a Haswell i3 (HD 4400 graphics) at 30Hz via HDMI (and it can't run both displays at the same time!). It's just a temporary solution -- the i3 4005U is def not a speed demon, further bottlenecked by a sllloooowwwww 5400rpm drive (SSD replacement incoming).
I can say that you'll immediately notice the flickering (though not as bad as even 60Hz on CRT I think), so unless you're going to get a graphics card (or a laptop) with DisplayPort 1.2+ soon, you probably better wait since prices are going down (new models are coming). What monitor are you considering?
"Any sufficiently advanced technology is indistinguishable from magic."—Arthur C. Clarke
"No way. Installing the drivers on these things always gives me a headache."—Guybrush Threepwood (on cutting-edge voodoo technology)
