First post, by gladders
Hey all, so thanks to advice on this forum I ditched the IBM Valuepoint motherboard I was looking at before, did a bit more research, and have decided on one of these motherboards.
I think it'll do best for my objectives, i.e. a sweet point between by 8086 and my 450Mhz PIII.
It has flaws - the upper right 'secondary cache' chips are likely fake, for example - but I am not looking for making a raw-power 486 here. It's mainly going to be backwards-looking, i.e. running those notoriously picky 286 and 386 programs and games via the Turbo button.
With that in mind, does it matter that much if I don't put any pipeline burst SRAM into the slot provided? Or is this less of a problem than I expected?
For example, would this fit in there fine? http://www.ebay.co.uk/itm/646731-Gateway-6467 … eAAAOSwzJ5Xdqgo
It comes with a 32MB RAM card as well.
And recommended CPU for my aims? Earlier someone suggested a 486DX 33Mhz - is that still recommended, or would a 66Mhz be better?
Thanks 😀
    1.43 MiB
    2.12 MiB
Reply 1 of 1, by kixs
You need this kind of cache module:
http://www.ebay.com/itm/Cache-Module-for-PC-C … 5-/201243815960
Difference between cache or no cache isn't that large. About 10-15% but it mainly depends on the apps/games used.
I'd probably use cpus with 16KB L1 cache (Intel 486dx4-100, amd 5x86DX5-133, Cyrix 5x86).
