Reply 40 of 47, by archsan
- Oldbie
wrote:Internet Explorer has Flash built in. The OS does not.
Check again. Any fresh install of Windows 10 Home/Pro.
For example, this is what I found when I have my laptop (Win10 Pro x64) upgraded to 1511 (10586). I have removed these stuff in the previous build, and then they're back again in this major version upgrade.
%windir%\System32\Macromed\*%windir%\System32\CatRoot\[...]\Adobe-Flash-For-Windows-Package*.cat%windir%\SySWOW64\Macromed\*%windir%\SySWOW64\FlashPlayerApp.exe%windir%\SySWOW64\Flash*.cpl <-- see it in control panel | System & Security%windir%\WinSxS\amd64_adobe-flash-for-windows_%windir%\WinSxS\wow64_adobe-flash-for-windows_%windir%\WinSxS\FileMaps\$$_system32_macromed_flash_%windir%\WinSxS\FileMaps\$$_syswow64_macromed_flash_%windir%\WinSxS\Manifests\amd64_adobe-flash-for-windows_%windir%\WinSxS\Manifests\wow64_adobe-flash-for-windows_%windir%\SoftwareDistribution\Download\...\amd64_adobe-flash-for-windows_%windir%\SoftwareDistribution\Download\...\wow64_adobe-flash-for-windows_HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_adobe-flash-for-windows_31bf3856ad364e35_0.0.0.0_none_ab9875376a174135HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_adobe-flash-for-windows_31bf3856ad364e35_0.0.0.0_none_b5ed1f899e780330HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Adobe-Flash-For-Windows-Package~31bf3856ad364e35~amd64~~0.0.0.0"Adobe-Flash-For-Windows-Package~31bf3856ad364e35~amd64~~10.0.10586.0" inHKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-Server-Gui-Shell-Package-shell~31bf3856ad364e35~amd64~~0.0.0.0HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Adobe-Flash-For-Windows-Package~31bf3856ad364e35~amd64~~0.0.0.0HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Adobe-Flash-For-Windows-Package~31bf3856ad364e35~amd64~~10.0.10586.0HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\amd64_adobe-flash-for-windows_31bf3856ad364e35_none_b4179b8118d18c9fHKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\wow64_adobe-flash-for-windows_31bf3856ad364e35_none_be6c45d34d324e9aHKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\wow64_adobe-flash-for-windows-deployment_31bf3856ad364e35_none_47a439c9d9f1351c
There are some other reg entries, but the above should be the key ones to remove. Also check their default ownership/permissions. 😉
Note that running Flash "uninstaller" from Adobe does not remove the above. I'm not sure what it does or if it really does anything useful.
"Any sufficiently advanced technology is indistinguishable from magic."—Arthur C. Clarke
"No way. Installing the drivers on these things always gives me a headache."—Guybrush Threepwood (on cutting-edge voodoo technology)
