First post, by computergeek92
Are the 440FX Pentium II boards able to be used with slot to socket converters with Mendocino Celerons or possibly the higher clocked 66FSB Coppermines? Are there modded BIOS availiable for certain boards? All Pentium II's ran at 2V, and so did the Mendocino Celerons. Would the normal slot 1 Celerons like the 400MHz model work too? Mendocinos may be my best bet due to older boards like this might be even less compatible with later Celerons. I read that 440LX boards had much more support for Celerons, but I don't generally take no for an answer. . .
Dedicated Windows 95 Aficionado for good reasons:
http://toastytech.com/evil/setup.html
