ISA cards unknown - INFO
First post, by Morris69
Hello guys
I'm new here, and i hope to be useful to someone. Also sorry for my bad English.
Well, i have three ISA cards that I do not know what they are (video card?, RAM expansion?)
Can you help me?
Thanks in advance
Morris
The attachment SDC12446.JPG is no longer available
Reply 1 of 10, by keenmaster486
If I didn't know any better I'd say that the first one is a CGA card, the second one is indeed an I/O board, and the third one I have no idea about.
Edit: also, welcome to the forum! And your English isn't bad at all.
World's foremost 486 enjoyer.
Reply 2 of 10, by Roman78
First one could be a SDLC adapter card.
Second some IO-controller, But no ISA.... But I See a Zillog Z08530 (serial port), a WD37C65C (a NEC Floppy controller), so it's some kind of IO. Unfortunately the picture does not show the numbers on the right. And a picture from the other side would also be cool.
And the third refers to an Siemens Computer according to the numbers on the card. At least there is a battery on it and some Ram 8 NEC D4464C-15L. And according to google it is 192 x 8 Bit static CMOS Ram. So some kind of BIOS card, strange is that is not on the mainboard.
Reply 3 of 10, by Morris69
Thanks for your replies
Unfortunately, google give me no information about this cards.
Anyway I think these come from very old computers.
For Roman78: here's the back of the 2nd card (I/O controller?!?)
If anyone has the same cards pls let me know.
Thanks again
The attachment SDC12451.JPG is no longer available
Reply 4 of 10, by Jorpho
Presumably, some kind of proprietary ribbon cable was used to attach that I/O card to some specific motherboard.
Without both the ribbon cable and the specific motherboard, there's really no point in keeping it around.
Reply 5 of 10, by Jo22
The last card contains a battery and ram.. Perhaps that's a ram disk for a proprietary machinery ?
Reply 6 of 10, by Jepael
1) SDLC adapter
2) Not a PC ISA card. Not PC stuff maybe. I'd say it is mainboard of a laser printer or something, but the floppy controller would not make sense.
3) 64 kilobytes of SRAM with battery back-up. So of course this is not CMOS RAM for BIOS, and quite small for a RAM disk. It could however be used to back up some code or data during power outages, so a system (a factory) can continue from where it was. Or maybe it is a ROM emulator for developing bootable BIOSes, who knows.
Reply 7 of 10, by BloodyCactus
the #2 is from a test system or data aquisition system. i dont see any common marks from its age (racal dana, keithley, bk, hp etc)
Reply 8 of 10, by keenmaster486
Note: This should be in Marvin.
Reply 9 of 10, by Morris69
Thanks for the info guys
I have very old stuff at home, 386/486/Pentium motherboards, AMD/Intel CPU , ISA & PCI cards (audio, video, printer, serial, controllers), hdd's MFM, and more, but these 3 cards will remain unknown....so I will use them as spare parts. 😉
Reply 10 of 10, by expandbadelynge424
Can you help me?
I think:
1. SDLC adapter
2. data acquisition system
3. SRAM
