ATI Driver Problems
First post, by Oldskoolmaniac
Im having problems trying remove a driver from my windows xp machine windows keeps installing it back and im trying to install catalyst 6.11 it installs but im still stuck with the corrupt driver (what a pain in the ass).
So my question is what is a good safe program to use without malware that will completely remove this crap from the registry and wherever it is out of the windows directory.
Motherboard Reviews The Motherboard Thread
Plastic parts looking nasty and yellow try this Deyellowing Plastic
Reply 1 of 2, by clueless1
You could try this, but I'm not sure it will work on "ATI" drivers:
http://support.amd.com/en-us/kb-articles/Page … ll-Utility.aspx
There's also this, but I can't vouch for it since I've never tried it:
http://www.guru3d.com/files-details/display-d … r-download.html
though guru3d.com is a pretty reputable site, so I guess it would be safe.
edit: and if you're comfortable with "doing it yourself":
http://forums.guru3d.com/showthread.php?t=379461
You can always scan the utility file with malwarebytes before running it, and upload it to virustotal.com to double-check.
Good luck!
Reply 2 of 2, by Oldskoolmaniac
Ill try those, im hopping i can remove this driver its from my xp disc i add driverpacks to the disc.
