Best Slot 1 Motherboard?
Reply 60 of 148, by luckybob
video editing, CAD, Running two things at once.
Reply 61 of 148, by Jupiter-18
If I would use it for retro CAD stuff, would it make more sense to go all the way to a Slot 2 PC?
Reply 62 of 148, by archsan
Jupiter-18 wrote:
Ok! Good to know!
So bottom line, what would a dual Slot 1 PC excel at?
At giving luckybob orgasm of course. 😜 Actually, quite a few other vogoners too!
"Any sufficiently advanced technology is indistinguishable from magic."—Arthur C. Clarke
"No way. Installing the drivers on these things always gives me a headache."—Guybrush Threepwood (on cutting-edge voodoo technology)
Reply 63 of 148, by nforce4max
archsan wrote:
Jupiter-18 wrote:
Ok! Good to know!
LoL, some of the stuff I got would certainly do the job. /hides everything
Reply 64 of 148, by luckybob
Reply 65 of 148, by Jupiter-18
So, is a Slot 1 PC worth it?
Reply 66 of 148, by luckybob
its no different than a socket 370.
Reply 67 of 148, by nforce4max
Pretty much this
Reply 68 of 148, by Jupiter-18
Well then, I'll probably go with Slot 1 since it is so different and cool. I think the CPU cartridge idea was a good one, since more can be put onto the cartridge itself, thus saving space for other chips on the motherboard. Also, it makes switching CPUs a breeze, and it takes up less space on the board.
Reply 69 of 148, by luckybob
If you want to make it harder and cooler, look for slot-A instead. My Voodoo2 setup is an AMD 1ghz slot A setup. Runs fast. All I need to find is a goldfinger device and Alpha heatsink.
Reply 70 of 148, by Jupiter-18
I've looked at slot A. I think for my Athlon build, I will choose Socket A. If Slot 1 and Socket 370 are really that similar, I won't build a 370 PC.
Reply 71 of 148, by Jade Falcon
Rank BANNED
BANNED
luckybob wrote:
I'm willing to bet he means PCI slots. V2's are pci only after all.
Reply 72 of 148, by Jupiter-18
Ooh! What is THAT gorgeous hunk of AGP power?
Reply 73 of 148, by luckybob
That is a slab of fiberglass, silicone, and copper. It sells for several hundred dollars.
Reply 74 of 148, by GL1zdA
Jupiter-18 wrote:
So if I understand it correctly: 3Dlabs - Pentium II FireGL - Pentium III Quadro - Pentium 4 […]
3Dlabs - Pentium II
Quadro - Pentium 4
Not so easy. There's quite a difference between a 3Dlabs 300SX based card (late 1994), 500TX (1996) and MX (1997). After this were the 3Dlabs Oxygens (before was the Dynamic Picture Oxygen V192, DP was later bought by 3Dlabs). Later, after they've acquired the workstation business from Intergraph, were the Wildcats.
FireGL is also a broad term. There were many FireGLs, on very different chipsets. There were even just "Fire" cards, before they could do OpenGL (Fire and the first FireGL, based on 3Dlabs 300SX, were manufactured by SPEA, later bought by Diamond).
The first Quadro was released when Pentium IIIs were popular, before Pentium 4 was sold. It was the ELSA GLoria II (had one in that days), SGI also had also their Quadro based VPro VR3 cards.
Of course there were many other OpenGL workstation cards in the 90s'. Intergraph was the PC high-end of 3D graphics. E&S did some nice systems (never seen a Freedom Series subsystem). OKI, NEC, Lockheed Martin, AccelGraphics and many others, even SGI had their PC-like Visual Workstation (a Quad Pentium III Xeon monster).
getquake.gif | InfoWorld/PC Magazine Indices
Reply 75 of 148, by Jupiter-18
So, if I wanted to get the craziest, most powerful 2005 era workstation, what would I need? Just out of curiosity. Also, what would be the most powerful graphics card I could get on a dual cpu slot 1 Pentium 3 motherboard?
Reply 76 of 148, by luckybob
2005? Thats late P4 era. Google the Asus ncch-dl motherboard, put 2x 3.8ghz irwindale processors. The options are endless and quite frankly boring.
Reply 77 of 148, by GL1zdA
Nope. 2005 is AMD. Dual Opteron + GF6800 SLI FTW! Look at the God Box: http://arstechnica.com/gadgets/2005/04/system-guide-200504/
Reply 78 of 148, by luckybob
Pci-e machines dont count.
