First post, by nertx
Im trying to get an old 16bit application working with dosbox. It's running fine on windows 7 32bit and the "integrated" dos mode but I want to use 64bit OS so dosbox is the best option.
I was able to get it startet but in the dosbox window some text is missing (see image) - there should be text in the grey and black area below (see image):
Any idea how I can fix this?
Thanks!
