First post, by superfury
Anyone has requests for new features on my x86EMU(from now on named UniPCemu) emulator? Anything that is still missing?
UniPCemu Git repository
Reply 1 of 13, by leileilol
A distinguishing name is a big one
Reply 3 of 13, by Jepael
My first thought was Sound Blaster audio. But for example for Wolfenstein 3D, you emulate already all the necessary stuff (PC speaker, Adlib, Disney Sound Source) so nothing is missing.
Some newer games or demos do not support DSS, so perhaps they would benefit from Sound Blaster emulation. Some early games had Game Blaster music but usually they supported Adlib as well. I think Zak McKraken did not support Adlib, but it did support Game Blaster (forgot if this was with real hardware or just ScummVM).
Reply 4 of 13, by MVoloshin
I've successfully compiled UniPCemu for Android with libSDL by Pelya, but it is unusable due to controls designed for PSP, etc. This implementation of SDL uses standard PC keyboard.
I think, for example, arrows should work as arrows and Enter as Enter.
Reply 5 of 13, by MVoloshin
Then, SDL keyboard has no Numpad at all.
And I cannot switch to Direct input mode, because I am unable to press both mouse buttons (because of touchscreen).
It would be nice to add separate controls for Android (#ifdef ANDORID ... #endif)
Reply 6 of 13, by MVoloshin
I've made Enchancement request in issues at Bitbucket page.
Reply 7 of 13, by superfury
I've currently modified the Android build to redirect to PSP input when using the Settings menu, and direct input when using normal emulation.
Settings menu mappings (instead of normal PSP-style keyboard mappings):
Arrows -> PSP DPad(arrows)
Enter -> Cross(confirm)
Escape -> Circle(cancel)
Space -> Triangle(Set defaults/unmount disk).
Is this enough to get it running on Android? I don't know how the Android face buttons (Back&Menu) are mapped, when I know I can map them to open the Settings menu to provide full Android support(assuming the device has a keyboard with normal keys of sorts).
Reply 8 of 13, by keenmaster486
Hmm, it would be great if you could make it run on iOS 😀
World's foremost 486 enjoyer.
Reply 9 of 13, by superfury
Well, it should already be possible to compile and simply run on it, although there's no method of input on that device(and other touch-only devices) yet. I might have to create a full OSK using the finger actions provided by SDL2.
Reply 10 of 13, by superfury
I've added a simple full 104-key OSK to the emulator, which should work on Windows(which I'm testing on) as well as any touch-only device. Simply tap on the OSK status indicator (which now displays K(eyboard, previously not showing anything), M(ouse), G(aming) and the new O(SK) indicator, which enables or disables the OSK when clicked/tapped on. The OSK itself directly redirects it's data to normal SDL events, which make the emulator see it as keyboard input(like a normal PC keyboard). The indicator can be found at it's usual position, at the bottomright of the emulator window.
Sound Blaster emulation(partly based on Dosbox, mostly for it's ADPCM decoding code) should be working as well, but for some reason some software either hangs(8088 Corruption), plays sound(Wolfenstein 3D) or simply throws an error validating(Sound Blaster 2.0's diagnostic.exe, when checking the DMA step).
Reply 11 of 13, by superfury
I've added mouse emulation to the finger OSK. Now mouse clicks and fingers will:
- Press the emulated left mouse button when the left 1/3th of the screen is pressed(mouse)/tapped.
- Press the emulated middle mouse button when the middle top 1/3th of the screen is pressed(mouse)/tapped.
- Press the emulated right mouse button when the right 1/3th of the screen is pressed(mouse)/tapped.
- Simple move the screen when the rest of the center 1/3th of the screen is used(no buttons mapped to provide moving without pressing any buttons).
- Also fixed a bug which caused the event filter to execute events twice, causing double or more actions to performed at once. This would cause the middle mouse button to lock itself permanently into Direct Input mode, without any way out(because the event filter handles it once, which unlocks the Direct Input mode, then the main callback fires(main thread), which handled it again(causing the just unlocked Direct Input mode to be locked into Direct Input mode again).
Reply 12 of 13, by superfury
UniPCemu is now properly able to basically(full touch input and Settings menu support) run on Android devices using either lib-SDL(Pelya's) or SDL2 with the toolchains(SDL2 on Android SDK/NDK). The only problem left is that it seems to be idling after returning from the Settings menu or boot option(the yellow text for configuring the emulator before emulation starts)? The CPU Speed percentage and cycles tell me that it's not running at all for some reason? Is there a problem with SDL_GetTicks on Android builds?
Edit: It's running now, but it's incredibly slow? Only about 2500 4.77MHz CPU cycles/S?
Reply 13 of 13, by superfury
With more recent builds, the emulator runs a lot faster(fixed some things that were called(like rendering) when not needed, producing unmodified frames). It's now running at up to 20% speed on my Android device(Samsung Galaxy S7 at 0.5MIPS).
