First post, by keenmaster486
I have this laptop, vintage '96 or thereabouts, and lately I've noticed some strange effects going on at the top of the screen, like several pixels up there went bad at once:
1.84 MiB
So does this mean I should worry about my screen, or not?
World's foremost 486 enjoyer.
Reply 2 of 5, by Jorpho
Looks to me like some layer or another became unglued.
But what is there to worry about, really? It's not like you're likely to be able to replace the screen of a 1996 laptop.
Reply 3 of 5, by FFXIhealer
You'll know your screen is about to die when you show up at the hospital and it is on life support and its BP has dropped well below safe levels and the EKG shows weak and erratic signals. Doctors will not be around because they have already given up. Only the nurses are on-hand to administer fluids and meds via an IV drip. The screen will have difficulty breathing and will probably die in its sleep.
Or it could just be a gunshot wound...
Reply 4 of 5, by nforce4max
It depends on the type of panel we are looking at, if it is a TFT it should hold up for a few more years. DTSN panels or something like that are Horrendous for degradation.
Reply 5 of 5, by archsan
So the pixels are confirmed dead with RGB LCD test tool (or just uniform red/green/blue background)?
"Any sufficiently advanced technology is indistinguishable from magic."—Arthur C. Clarke
"No way. Installing the drivers on these things always gives me a headache."—Guybrush Threepwood (on cutting-edge voodoo technology)
