NFL Gameday 99
First post, by buckeye
Anyone know if this game was any good or not? Thought about getting it for win98 rig.
Reply 1 of 3, by stranno
It works properly on Windows 10 64-bit under Direct3D5 renderer using dgVoodoo. I guess it will work perfectly fine under Glide too using dgVoodoo or nGlide.
You need the 1.1 patch in order to avoid the Pentium-only error.
I dont know if it is a good game, i dont understand NFL.
Reply 2 of 3, by buckeye
Under Windows 10 keep getting the error "requires at least a pentium processor or equal". Tried different compatibility settings to no avail. Tried nglide - no dice. CPU is an early i7, but you got it working? Any ideas?
Reply 3 of 3, by Jorpho
