First post, by Guest
thanks for the advice, but in case you hadnt noticed, next to my name it says "guest". which means i'm not registered for this forum. which means i CAN'T post in the DOSBox games/apps forum.
is it so wrong to need help if ur not a member of the forum?
roSe
Reply 1 of 4, by avatar_58
Is it so hard to take 10 seconds to register? 😒
Reply 2 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
well if you want help it requires some effort from your part.
(registering)
it makes it easier as every guest is the same. so when dealing with some personal like a problem it's nice to have a name.
Water flows down the stream
Reply 3 of 4, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
@guest: I think that anybody wanting specific help should register. It is not that much ... It also helps to get better thought out questions. It is far too easy to write anonymously without even bothering to search/read posting guidelines/think... My idea is that registration forces people to think a bit more about what they post.
Be glad that the DOSBOX General allows anonymous posting. If it was according to me, it would require registration as well.
Mirek
Reply 4 of 4, by Snover
BTW, I only send out viagra spam once a week, so don't worry. 😉
Yes, it’s my fault.
