First post, by Jinxter
Take a look at my retro Pentium 2 computer. I am very satisfied with the setup, but please advice/give your opinion.
https://www.youtube.com/watch?v=2Do1aUw9jH8
Dell Dimension XPS R350
Compact Flash 8 GB on IDE
Creative Voodoo3 (AGP) & Voodoo2 (PCI) - for compability with older games. I have only installed driver for the Voodoo 3 / AGP card. I used glide.dll/ovx in the game directory for older games.
Sound Galaxy Waverider Pro 32 - 3D - ISA16. This card has a very good MIDI chip. Way better than SB.
With 384 MB RAM i decided to use 65MB for ramdrive and configured Windows and dos to use the ramdrive for swap and temp files.
Windows 98 SE with config.sys and autoexec.bat
In my config.sys i am using uide.sys as a cd-rom driver. As far as i understand uide.sys is also workes as a hdd cache. When using uide.sys Windows98Se does not work.
In autoexec.bat i use ctmouse fra Freedos and XMSDKS to create a ramdisk (c:\XMSDSK\XMSDSK.EXE 65000 g: /C1 /T /Y). This ramdisk is also used in windows by changes settings in system.ini to direct PagingFile=g:. I Also set ConservativeSwapfileUsage=0 (maybe this is already default?) I also put set temp=g:\ in my autoexec.bat
Is this a good setup for a 384MB Pentium 2, with a Compact Flash card for HDD?
Check out my YouTube channel: Retro Erik https://www.youtube.com/c/RetroErik
My collection: https://retro.hageseter.com
X: https://x.com/Retro_Erik
Reply 1 of 19, by Jorpho
I don't see why you need both a Voodoo2 and a Voodoo3. Is there a specific game you actually want to run that is known to have compatibility problems with a Voodoo3?
It makes sense to use a ramdrive with more than 512 MB of RAM, but with 384 MB you're probably much better off leaving Windows to manage everything. There are many pages discussing the various complex reasons for this out there; http://freepctech.com/pc/002/XP_MYTHS_001.shtml contains a blurb. 65 MB isn't very much for both swap and temp files anyway.
Yes, I'm pretty sure Windows is supposed to take care of all of that.
You should get the Intel Application Accelerator for UDMA support.
Yes.
https://support.microsoft.com/en-us/kb/223294
Reply 2 of 19, by nforce4max
Jorpho wrote:
I don't see why you need both a Voodoo2 and a Voodoo3. Is there a specific game you actually want to run that is known to have […]
Yes.
There is a small number of games and demo or two that only work on the V2 for whatever reason but they are not memorable, the same goes for the V1 but no one plays those games/demos except once just to try out. OP is better off just using the V3.
Reply 3 of 19, by Arctic
Please tell us which games aren't working on your voodoo 3.
I will try to make them work and post the results (if I have the respective games)
I am sure I can run any glide game on the voodoo 3.
Challenge accepted 🤣
Nice machine by the way 😀
Reply 4 of 19, by Jade Falcon
Rank BANNED
BANNED
Arctic wrote:
Please tell us which games aren't working on your voodoo 3. I will try to make them work and post the results (if I have the res […]
Mech warrior 2
Reply 6 of 19, by Jinxter
The readme file for App Acc says it only workes for P3 and P4:
1. The system must contain the following Intel products:
* Intel(R) Pentium(R) III or Pentium(R) 4 processor
* Intel(R) 82801AA, 82801AB, 82801BA or 82801DB
controllers
I have a P2, is it worth a try?
Will Smartdrv (startet in autoexec.bat) have any effect in Windows98?
Reply 7 of 19, by Jinxter
Thanks for the link to the Windows XP Myths. I am using Windows 98SE so i am not convinced that the myth regarding Ramdrive is accurate to use in my case.
i State that i am using a Ramdrive to :
1. Improve overall speed. My thinking here is that i am using the machine mostly for retro gaming. Those games does not utilize all available memory, and somehow "forced" windows to swap memory. As "evidence" i can see that my swapfile is created after running some games. Ex. after playing Quake2 i can see that windows has created a swapfile i ramdisk that is about 16MB - sometimes larger. One could argue that this would not have happened if i did not have a ramdrive, but then again why would 65Mb more ram, reduce swapfile when playing Quake2?
2. Reduce wear on my Compact Flash. This page discussed the life span issued on Compact Flash https://docs.oracle.com/cd/E19469-01/820-4893 … pact_flash.html: "A disadvantage of CF is its limited life span. The card’s life span is dependent upon the number of write/erase cycles it receives. A block of memory on a CF card can only sustain a limited number of write/erase cycles before it degrades, and the card becomes unusable (reading does not degrade CF). In this respect, an OS can place a high demand on a CF card, because it performs numerous write-intensive tasks such as logging and swapping."
I am therefor deducting that using a ramdrive for both temp/tmp files and swapfile will prolong the life of the CF.
Please give your opinion.
Reply 8 of 19, by Jorpho
Jinxter wrote:
1. The system must contain the following Intel products: * Intel(R) Pentium(R) III or Pentium(R) 4 processor * Intel(R) 828 […]
controllers
Whoops, I misread that. I suppose you probably shouldn't use that, then.
I doubt it. I tried to find definitive reference stating that it won't do anything, but all I could find was http://www.computerhope.com/smartdrv.htm .
Please keep in mind that people have been running Windows 98 for almost twenty years now and if there was something to be gained from using smartdrv – or 65 MB RAM disks, for that matter – it would be very well-documented.
Yes, Windows 98 is pretty much designed to swap RAM. There is a blurb about this on the XP Myths page as well (see "Disable the Paging File"). That is also why I am pretty sure using less than 65 MB for your page file is probably going to cause problems.
Reducing wear on your CF card is an interesting argument, but I doubt you are actually likely to run up against the limit of write/erase cycles simply due to swap file usage.
Reply 9 of 19, by Jinxter
After reading the XP Myths, presuming it's the same in Windows 98, i think i will keep the swapfile on the c: drive. Keeping the ramdrive for temp files, could be a problem if a program would need more temp space than i allocated.
Also, i think i will try the Intel Application Accelerator. The readme file says it will work on Intel 82801AA Chipsset. I believe that I have this chip. I am not 100% sure, but i know it is a Intel 440BX motherboard. Don't think wrong drivers will destroy anything.
I'm planning to use CrystalCPUID 4.15.5.452e to test hdd/CF speeds before and after.
Reply 10 of 19, by Tiger433
Descent (1) and Tomb Raider (1)
I played with Voodoo 3 Tomb Raider 1 without any problems years ago.
W7 "retro" PC: ASUS P8H77-V, Intel i3 3240, 8 GB DDR3 1333, HD6850, 2 x 500 GB HDD
Retro 98SE PC: MSI MS-6511, AMD Athlon XP 2000+, 512 MB RAM, ATI Rage 128, 80GB HDD
My Youtube channel
Reply 11 of 19, by mrau
under linux i would use tmpfs, which would let me use physical memory for ramdisk up to a predefined point and then grow on disk if theres not enough memory - no such thing for windoze with all those ramdisks available?
Reply 12 of 19, by tincup
From my experience compatibility issues between different Voodoo cards was most pronounced between the V1 and V2 as a fair number of early accelerated games were statically linked to the V1 and didn't always work on a v2 or later card out of the box. On the other hand adding appropriate environmental variables to the autoexec.bat cured most of the issues IIR. I don't know if a similar trick is possible with a V2/V3 setup.
Reply 13 of 19, by Jinxter
When trying to install the Accelerator i was denied due to "incompatible hardware"
Reply 14 of 19, by Jinxter
Could you maybe send me the glide.* files you are using in the Tomb Raider folder?
Also i got Descent working.
Reply 15 of 19, by Tiger433
I used patch file from Tomb Raider CD and I have there with Voodoo 3 AntiAliasing there even when I ran that game in pure DOS much years ago. I played that some about 10-12 years ago. I normally installed game and only I copied patch to game directory. But today I haven`t my Voodoo 3 and other things I used in that time and I miss all that every day.
And read that - Tomb Raider inventory hang with Voodoo3 3000 and Glide patch
So you can see that is possible to run Tomb Raider on Voodoo 3.
My Youtube channel
Reply 16 of 19, by PhilsComputerLab
Tomb Raider is easy. There are 2 patches. One called 3dfx patch, the other one Voodoo Rush patch. 3dfx patch only works on V1, Voodoo Rush patch works on V3. Small differences, Laura won't have a shadow with Voodoo Rush patch.
I don't know about the other games though.
YouTube, Facebook, Website
Reply 17 of 19, by mrau
is the low level api documented anywhere anyway? i bet some skilled guy could fix that..
Reply 18 of 19, by Stiletto
what are you talking about? the Voodoo Graphics Tomb Raider patch?
It's not a low-level API. As I understand it, it's still the standard Glide library (in this case, a version of the library compiled for Voodoo 1 cards). The library is just statically linked with the binary rather than dynamically linked. See tincup's post. Also see Voodoo 2 DOS Glide compatibility matrix
Yes, maybe someone skilled could maybe fix it. There's a reasonably sized list of statically linked games and patches.
do the Fandango!" - Queen
Stiletto
Reply 19 of 19, by mrau
@Stiletto, well Glide is one thing, a point where this problem can be tackled - maybe, depends on the drugs taken by 3dfx engineers;
what i meant - this statically linked software still works on newer cards, right? so the lowlevel way of doing things still i similar - or do i have to stop taking my pills?
