CLI - DIR switches?
Here you can discuss the development of patches.
Re: DIR switches?
Postby moejoe » 2016-9-09 @ 12:58
Yes, it is a patch against DosBox 0.74 and should still work with current SVN trunk. The patch has been incorporated into DOSBox-X in the meantime.
User avatar
moejoe
Re: DIR switches?
Postby LazerTag » 2016-9-09 @ 20:51
Thanks, got it patched and built no problem.
So while it fixed the initial issue 'illegal switch /on' which is great! I'm still unable to run the application, too bad. :( I get a "SHELL:Multiple command on 1 line not supported" in the terminal. So close. I don't suppose there is a hack somewhere for that? :)
was fun messing about with this today though. I've not compiled anything in years, lol.
thanks again !
LT
LazerTag
Re: DIR switches?
Postby moejoe » 2016-9-09 @ 21:09
To me it sounds like you just might need to do some minor tweaks to batch file that causes the error.
User avatar
moejoe
Previous
Return to DOSBox Patches
Who is online
Users browsing this forum: MetalMilitia and 2 guests
