Will DOSBox help me?
First post, by bilwar
I bought an old wordprocessor at a yard sale, it uses MS-DOS to save files to a floppy disk drive, its made by Brother, I was able to find the manual online, for free.
Looking over it, the keyboard/typewriter has a port that the monitor would plug into and the floppy disk drive, I took it to an electronics store, looking for something I could plug into it to get it to either print or save files to, they found an adaptor that fits the plug on the keyboard, and would plug into a standard USB port on a computer.
The computer that I use the most has Windows 10 on it, I also have a netbook with Windows 7 Starter and a desktop with Vista and a old laptop with XP on it.
Plugging the cord into a USB port on the Win 10 Laptop after I installed the driver from the CD the cord came with, followed by turning on the keyboard-wordprocessor, did nothing, it cant find it, so, thanks for any help or advice
I also have the monitor, they both seem to work
Reply 1 of 2, by leileilol
No it won't. Dosbox is for games. Dosbox is not a crutch for legacy IT solutions. Use a VM.
Reply 2 of 2, by Jorpho
It is quite difficult to begin to suggest anything without knowing more about this specific "plug on the keyboard". If it is a serial-to-USB cable (or RS232-to-USB, as it may be called), then DOSBox may not be necessary at all and it is quite likely that any Windows terminal program may suffice.
Why don't you just provide a link to the manual you found?
