First post, by manuelink64
Hi fellows!
I tried to use a 8.4GB HDD on my 486DX4-100, 64 MB RAM EDO with XTIDE Universal Bios (EPROM) on a NIC card (dlink DE220),
the XTIDE works wonderfully well, I could format to FAT32 and install Win95OSR2.5, but....
Windows refuse to boot, only on "safe boot mode" works. 😵
Probably the win 95 IDE driver controller don't recognize the XTIDE implementation.
What i can do?
thanks in advance!
[Unisys CWP] [CPU] AMD-X5-133ADZ [RAM] 64 MB (4x36) FPM [HDD] Seagate 8.4GB [Audio] SB16 SCSI 2 (CT1770) [Video] ATI Mach64VT2 [OS] Windows 95 OSR2.5
Reply 1 of 10, by luckybob
XTIDE was not designed for this. You should use a standard ISA/IDE card. the majority of 486 boards I've dealt with have no problems handling a 8gb hard drive on their own with a simple dumb isa/ide card.
Reply 2 of 10, by manuelink64
maybe I am wrong, but i'm using The XTIDE Universal BIOS (XUB), not the XTIDE PCB...
XUB makes it possible to use modern large ATA hard disks or Compact Flash cards on old PC's...burning in a eprom an put in on a NIC/ISA/IDE card
Reply 3 of 10, by Imperious
Luckybob said it right. It's not designed for that. As far as I know, XTIDE is designed for larger hdds in Dos only.
You can use a larger hdd, but will need to install a software overlay like Ontrack or similar.
Reply 4 of 10, by keropi
yeah as luckybob states you don't need any extra IDE BIOS for a 8GB HDD... just use the mobo's bios with a controller and you'll be fine
Reply 5 of 10, by manuelink64
it's a shame 😒 thanks guys!
well, maybe I will try to format the hdd in four (FAT16, 2GB) partitions and then install DOS6.22+win311 😊 .
regards!
Reply 6 of 10, by Imperious
Why not just use an overlay as I mentioned? Then You can use a larger hdd with win95 and fat32.
Reply 7 of 10, by luckybob
Ive never even remotely needed more than 2gb for dos.
Reply 8 of 10, by Jo22
Out of curiosity, does this Universal BIOS thingy cooperate well with protected mode drivers ?
I'm thinking of FastDisk or OS/2's own disk driver.
Especially Windows 3.1 is what me worries a bit. It's WD1003 driver is quite stable, but also a bit paranoid.
In case of doubt it will instantly cease operation to avoid data loss.
Here's an article about this:
How to please WDCTRL
http://www.os2museum.com/wp/how-to-please-wdctrl/
Reply 9 of 10, by BloodyCactus
XTIDE bios is a real mode INT13 replacement. it does not work with protected mode, windows + os2 bypass real mode int13.
on a 486, there is no point using xtide. just attach a CF card directly to the standard ide port.
the whole 'XT' in 'XTIDE' denotes that its designed to work with 8088/8086 8bit class machines.
Reply 10 of 10, by NJRoadfan
The XTIDE BIOS has an AT version for use as a replacement Int 13h BIOS on newer machines. It does work with Windows 9x, but the esdi506.pdr driver requires that a drive type be set in the CMOS in order to work. This thread details the problem and has a patch/workaround: http://www.vcfed.org/forum/showthread.php?514 … ndows-95-issues
