vDosPlus is general-purpose non-gaming DOS emulator for both 32-bit and 64-bit Windows, based on vDos and DOSBox. Unlike the official version of DOSBox, which is specifically designed for DOS gaming, vDosPlus is designed for running normal DOS applications. Compared with vDos, while vDosPlus has all its features such as built-in 4DOS 8.00 shell which provides powerful command-line functionalities and printing to both PCL, PS and Windows-only (GDI) printers, vDosPlus has many unique features too, such as tighter integration with Windows, enhanced keyboard, mouse and display support (the feature list is long).
vDosPlus was once known as vDos-lfn because its initial focus was Windows-style long filename (LFN) support, but now it contains far more unique features than LFN support. It is based on mature projects and was also well tested by for example the XyWrite community, so it should be considered pretty stable as well. The home page of vDosPlus is now available at the following address. You can find its latest versions (both installers and portable versions are available) and further information in the vDosPlus home page.
http://www.vdosplus.org/
Please feel free to test it and leave any feedback and other comments, either here or in the vDosPlus discussion board (which is just open). Thanks!
P.S. I think this thread belongs to the DOSBox Patches forum. But should there be a DOSBox Forks forum for all software forked from DOSBox too?
