Reply 20 of 104, by FGB
Btw this is the error when I load the GUS soundbank conversion. Before the error occurs it lists and loads all the samples up to the mentioned number.
1.62 MiB
Error
So it is missing sample # 452 but when I open the WFB soundbank with AWAVE it reports only 321 samples and I can't figure out which sample is missing. That's strange.
www.AmoRetro.de Visit my huge hardware gallery with many historic items from 16MHz 286 to 1000MHz Slot A. Includes more than 80 soundcards and a growing Wavetable Recording section with more than 300 recordings.
Reply 21 of 104, by Rawit
Perhaps I've an idea where the "too many samples" issue comes from. Back in the dinosaur age when I was converting patches for the Gravis Ultrasound, I noticed that an SF2 instrument can have layers with multiple waveforms. These waveforms aren't exclusive to the instrument. This means 002 Piano can point to the same waveform as 001 Piano. Two instruments, one shared waveform. But the Gravis PAT format doesn't work that way, so on exporting it just makes an copy of the waveform for each instrument that uses it. I think the same thing is going on with WFB. Hence the size increase when going from SF2 to WFB. Shared waveforms/samples are copied, increasing the size and going beyond the sample limit.
Edit: In the screenshot I see you use firmware 1.14. I believe 1.15 is the latest available. Probably doesn't make a difference but still worth trying.
YouTube
Reply 22 of 104, by bristlehog
MAUI firmware v.1.15 is attached.
Fabian, you had a broken WFB file (6 300 000 bytes instead of 6 481 276) as stamasd already mentioned. Did you fix it?
    osmaui.zip
    30.84 KiB
    102 downloads
Hardware comparisons and game system requirements: https://technical.city
Reply 23 of 104, by FGB
Let me recheck again.
//edit: No, the file I tried loading to the MAUI is the same as it should be. 6.481.276 Bytes big. Although the WFSET detects a different size for some reason (The size is diplayed in the picture above, maybe the difference is a overhead of information and SETWF just reports the actual sample size in total). I will try with the newer firmware (thanks!) and report back.
//edit2: With firmware 1.15 the error remains the same (with the same report).
//edit3: I will test again with my recently new aquired TropPlus. Result (Troplus firmware 1.20: Exactly the same!)
Reply 24 of 104, by bristlehog
Never had anything ICS-ish, but just coughed out the $100.24 for a new-old-stock Maui. Seems I will participate somehow.
Meanwhile, Fabian, what is the date and size of your WFB loadup utility (WFSET or what was its name)? We might be able to find a newer one if any.
Reply 25 of 104, by FGB
Can't wait for your participation!
Well I use the same version as I uploaded in Posting #1, I just checked, it is version 1.43.
Reply 26 of 104, by bristlehog
Note that Awave Studio is powerful enough to apply any effects (reverb inclusive) to any bank.
Reply 27 of 104, by bristlehog
I have 82 SF2s under 9 megabytes of size. I took them and batch converted to WFB with Awave Studio. More than half refused to convert complaining that there are too many samples per bank to fulfill WaveFront standards. Nevertheless, here are remaining 36 WFB banks: http://geryon.ru/wfb_8mb.zip.
Whoever wants them soundbanks converted, send them my way (err, too many Witcher 3 lately).
Reply 28 of 104, by bristlehog
It seems that there is an alternative (unofficial) piece of software to manipulate the Maui (should also work with Tropez, dunno about Tropez+), including WFB load. It's called SETMAUI and has an additional graphical interface to it named MAUICTRL. Find them attached.
SETMAUI readme excerpt:
USING SETMAUI
SETMAUI [ [/|- options] [filename [,x [,y [,z ]]] ] [/|- options] ]...
[] means optional
| means exclusive or
... means etc.
If you don't add any parameters you'll get a short message on how to get
help.
If you specify a filename it means you want to download a file.
Now the valid extensions are:
.WFB - Bank file
.WFP - Program file
.WFD - DrumKit file
- .WFB files
The software download all samples, patches, drumkits and programs
that are in the Bank.
This action may overwrite the internal samples. See NOTES.
You need not specify any other parameters because all rooms for
the samples and patches are fixed in the .WFB file.
Sample: SETMAUI gm_maui.wfb
    mauictrl.zip
    9.88 KiB
    94 downloads
    setmaui.zip
    40.35 KiB
    112 downloads
Reply 29 of 104, by FGB
Thanks for your work, bristlehog!
I tested the FANTA 8GM.WFB on the Troplus with both SETWF and SETMAUI and both result in the same error as described before, but this time it stops loading at sample # 425. Very strange!
To rule out the possibility that anything is running out the cards sample RAM I tried the converted Chaos 2MB soundbank which resulted in the same error, this time at sample # 144. The Anson Lam's 512KB soundbank fails at sample 101. Arrrgh 🙁
See the below picture of SETMAUI:
2.08 MiB
SETMAUI ERROR: Could not open file..
I also switched between 24 and 32 voices with no difference. At one point the Tools stop loading the soundbank.
Maybe its worth mentioning that any soundbank reports 128Prgs/1 Drumkits/256 Patches and 512 Samples). Maybe, just maybe the WFB format expects 512 Samples to be present.
Reply 30 of 104, by stamasd
I'm wondering if the RAM you're using with your card may be faulty. Can you try another pair of sticks?
Wow that's a lot of money. Sorry for that. I managed to get the last card still priced at $22 from the same seller- seems that just after I bought that he bumped the price to $31, and then to $45.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 31 of 104, by FGB
I think the sticks are ok but I will try other sticks.
//edit: Now testing with 2x 1MB sticks instead of the 2 x 4MB sticks I had in the cards before. Result: Unfortunatlely nothing changes. The small banks still refuse to load, the error remains the same.
Another observation: Loading WFB files requries Extended Memory which is allocated before the samples begin to load.
There is another method to upload the samples to the cards RAM: Via the MPU-401 interface. This means very slow transfer, like over the waveblaster header with the RIO board. Maybe this works.. Now trying to load the 512KB bank, having 30% within 5 minutes - woohoo 😁
Reply 32 of 104, by bristlehog
It might be worth a check, but I suspect that Fabian's RAM is ok. What's supposedly not ok is Awave's work with WFB (who will ever believe that any bank has constant number of samples!) But it's still but a guess.
I applied a quick and dirty fix to that GUS WFB bank, give it a try: http://geryon.ru/gusdirty.zip
Reply 33 of 104, by bristlehog
It's still $45 but I had to pay $55 for shipping to Russia.
Reply 34 of 104, by FGB
Thanks! I will. just waiting for the result of the 512KB bank.. still loading.. 😉
//edit: 512KB bank still failed after loading all the samples.. still couldn't find sample #101.
//edit2: Well bristlehog: YES MAN! Thanks a lot! Loading completed! Midis soundend all right in GSPLAY! (did skip through a few standard midis. descent sounds odd but I remember it sounding off also with the GUS.. The whole bank sounds like a GUS with effects processor! Of course quite similar to the original patches of the Tropez+, but that was expected. I think that was the first huge milestone in our project - finally a working converted soundbank!
Screen attached below - This time it reported 451 samples and not 512. What exactly did you do and can it be done in a batch to all of your .SF2s?
1.86 MiB
SETWF loaded the GUS 4MB soundbank converted by bristlehog!
Reply 35 of 104, by bristlehog
I just changed the number of samples in WFB header to a number of samples actually present there (451, judging by the fact that sample #452 failed to load).
Number of samples is a word value located at 48h offset. So, I changed 200h (512) to 1C3h (451) and here we are. I don't yet think this can be applied in a batch since I can't figure how to determine actual number of samples in a WFB bank apart from trying to load it and receive an error at (n+1)th sample. However, we might tackle it later. For now, we can [probably] quickfix any Awave-made WFB bank by putting the right number of samples into WFB header manually instead of omnipresent 512.
I'm not even sure that such a fix won't break anything. We've got to experiment more.
Reply 36 of 104, by FGB
OK I understand. In the trial version of AWAVE one can count the actual samples with "view ---> item count". GUSDIRTY.WFB reports 129 instruments and 321 waveforms. Thats 450 in total. I think that SETWF and SETMAUI just count both together as SAMPLES. So these together are 450 and the drumkit make it 451: Et Voila! Thats the same number you edited.
So keeping this in mind makes it now very simple to find out the correct number for the 48th offset.
I will "dirty edit" the FANTA 8MB soundbank and / or the CHAOS 2MB soundbank. The numbers for the offset are 424 and 143 .. I think we get closer. If I'm right both banks will load and work! Can't wait 😁
Reply 37 of 104, by bristlehog
FGB wrote:
In the trial version of AWAVE one can count the actual samples with "view ---> item count". GUSDIRTY.WFB reports 129 instruments and 321 waveforms. Thats 450 in total. I think that SETWF and SETMAUI just count both together as SAMPLES. So these together are 450 and the drumkit make it 451: Et Voila! Thats the same number you edited. So keeping this in mind makes it now very simple to find out the correct number for the 48th offset.
That was my first guess too, but nope, it won't work this way. The Fanta GM WFB contains 65 instruments and 234 waveforms, but 424 samples according to your screenshot, while 234+65+1=400.
Reply 38 of 104, by FGB
It would have been so easy, too easy as it seems.. 😒 I edited the FANTA 8MB bank to 424 samples and it loads but some instruments are missing and making strange noises, like the Synth Strings. Other instruments play well. Still a lot of work to do I guess..
Reply 39 of 104, by bristlehog
I can think of two guesses right now:
1) Awave Studio won't write correct samples number to a WFB bank, always writing 512. (But Fanta GM won't probably glitch then).
2) It's required to always have 512 samples in a WFB bank. Awave Studio just won't complete the bank sample structure, writing only samples that are physically present. But then default gm_maui.wfb, which is not an output of Awave Studio, contains 332 samples, not 512. (There's also "332 of 512 samples in use" string in SETUPSND output at your screenshots).
I'm bewildered.
