Reply 13960 of 57996, by Cyrix200+
Asus CUV4X-E and a Pentium III 667MHz
1982 to 2001
Reply 13961 of 57996, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
> some kind of video card or as internets says "monitor output card" with serial,few of mine mobos didn't posts with it
It appears the traces for the VGA-like connector only go to the pin row behind it. And with these chips it is not going too do video. It's some sort of special serial controller.
1+1=10
Reply 13962 of 57996, by NamelessPlayer
So, that thing I ordered arrived today: another Thrustmaster FCS. But this isn't the typical variety!
You wouldn't believe how hard it is to find the Mac ADB version these days. This one even came complete in box! Seems to work pretty well, too.
I've also put it next to my other FCS, which I got a while back with a WCS. I sadly don't have a Mac WCS to go with this, but I think I might be able to work out something if the Mac WCS is just a simple button + pot box like I think it is - only one DB-15 cable leading straight to the FCS, which doubles as a PC rudder pedal port. Just need to figure out the pinout so I can rewire my PC WCS accordingly.
As for why I went to the trouble of finding the ADB FCS, it's because pre-InputSprocket Mac sims like Flying Nightmares and A-10 Attack!/Cuba! have a direct interface for TM hardware, reading the stick, throttle and pedals natively as opposed to emulating the mouse. This is the only way I know of to get truly analog throttle and rudder control in such titles.
I know there were utilities for the Gravis Firebird 2 that could emulate the TM API for native support too, but I can't find 'em. I've got even less hope of finding some for the SideWinder 3D Pro.
Reply 13963 of 57996, by kanecvr
Finally, a WORKING, unadulterated, unmodified, unmolested voodoo 5 5500 AGP!
Top - the recycle center rescue with dead memory chips on one GPU
Bottom - all original working card
I've wanted one of these babies ever since I was a teen.
Big thanks to the VOGONS members who helped me track it down!
Reply 13964 of 57996, by Tiger433
kanecvr wrote:
Finally, a WORKING, unadulterated, unmodified, unmolested voodoo 5 5500 AGP! […]
It`s bad you can`t make SLI of them 🤣
W7 "retro" PC: ASUS P8H77-V, Intel i3 3240, 8 GB DDR3 1333, HD6850, 2 x 500 GB HDD
Retro 98SE PC: MSI MS-6511, AMD Athlon XP 2000+, 512 MB RAM, ATI Rage 128, 80GB HDD
My Youtube channel
Reply 13965 of 57996, by squareguy
Never seen one quite like this but I'm not extremely knowledgeable of all the YMF71x cards. PCB looks to be high quality and interestingly there is a 4556 IC on it and those make very high quality headphone amplifiers. I cannot tell by the pictures where all the traces go. I am hoping in 'line out' mode it is used as a buffer amplifier. Anyone heard / owned / etc the SM718 cards?
The attachment s-l1600 (3).jpg is no longer available
The attachment s-l1600 (2).jpg is no longer available
Intel SE440BX-2 Motherboard
Intel Pentium III 450 CPU
Micron 384MB SDRAM (3x128)
Windows 98 SE
Reply 13966 of 57996, by GoblinUpTheRoad
Picked up a Roland MT-32 old.
The attachment mt32.jpg is no longer available
And an Atari 1040STF, with extra yellow...
The attachment atarist.jpg is no longer available
Reply 13967 of 57996, by devius
rein_ein wrote:
some kind of video card or as internets says "monitor output card" with serial,few of mine mobos didn't posts with it […]
it have AMD N80C188 and also Zilog Z85C3008VSC
The N80C188 seems to be a microprocessor compatible with 8086/88 software, so it's not a video chip. That thing is probably not a video card at all despite the DB15 connector. It doesn't even look like a typical 8-bit clone video card.
Reply 13968 of 57996, by TheAbandonwareGuy
Some form of OEM CPU daughterboard perhaps?
RetroEra: Retro Gaming Podcast and Community: https://discord.gg/kezaTvzH3Q
Cyb3rst0rm's Retro Hardware Warzone: https://discord.gg/naTwhZVMay
Reply 13969 of 57996, by Batyra
Just got these two among some other cool retro-stuff...
Can you help me to identify the card on top? I can't find anything... There are some similarities to FAST AV Master - but it's obviously different card...
Thanks!
Reply 13970 of 57996, by stamasd
Nope. The 80C188 is the "microcontroller" version of the 8088. It has a few integrated peripherals but they aren't compatible with the IBM PC architecture and as such was never used as CPU for PCs (address mapping of I/O ports etc differ). https://en.wikipedia.org/wiki/Intel_80188
It was in fact used on peripheral expansion cards as a general-purpose microcontroller. I have seen it on ethernet cards and SCSI cards, modems and other I/O cards.
I bet that card is in fact a dual-port serial card, just with a weird VGA-like connector for the second port. I think I have seen VGA-like connectors on other serial cards. This was of course before VGA even existed.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 13971 of 57996, by BloodyCactus
Thanks!
SPEA card. SAA17998 is a genlock chip, SAA7110 is a dac/adc tv decoder, the zr36055 is a mpeg decoder.
probably its a dvd/mpeg decoder card. Ive not seen this particaular SPEA card before.
Reply 13972 of 57996, by TheAbandonwareGuy
stamasd wrote:
Nope. The 80C188 is the "microcontroller" version of the 8088. It has a few integrated peripherals but they aren't compatible wi […]
Ok yeah this is why I keep my mouth shut on pre-Pentium stuff. I know next to nothing about it.
Reply 13973 of 57996, by kanecvr
That would have been cool. The Quantum3D AAlchemy uses more chips and runs in multi board configurations but it only does AA. If you turn AA off it behaves like a Voodoo 4... 🙁
Reply 13974 of 57996, by CelGen
Here's a rather new but slightly oddball machine I couldn't resist the $30 for.
A Sony VAIO PCV-LX900. A weird 1ghz PIII box. The monitor is proprietary and one cable carries video, PS/2, audio and USB to the monitor.
The other thing is that the monitor is Wacom enabled. The monitor can tilt int a number of positions and the keyboard palm rests flips open and over they keyboard to become a giant palmrest and keyboard cover.
Everything but the ram was stock. The drive however had been formatted and no recovery CD's were included with the machine. 😢
Now for the ugly.
At first I thought someone had dripped wax on the LCD but upon inspection it looks like something has scratched the LCD and caused the matte surfacing to swell up. There's also a strange haze in the corner. that I could not wipe off.
Well that's because something is really unhealthy about the LCD. Is there a fungus or something living in the diffuser??
Reply 13975 of 57996, by luckybob
@celgen
Reply 13976 of 57996, by Jade Falcon
Rank BANNED
BANNED
I splurged
The attachment s-l1600.jpg is no longer available
The attachment s-l16001.jpg is no longer available
The attachment 23.jpg is no longer available
Dose 1600 x 1200 @ 75Hz
Reply 13977 of 57996, by SW-SSG
*snip*
Interesting system! The screen looks like a DSTN LCD, possibly badly degraded (or just damaged from whatever it was that scratched it...)
Reply 13978 of 57996, by CkRtech
Celgen - It is possible the LCD part of that screen is used in multiple displays from the time period. I imagine you can open it and replace the LCD - especially if you can get a part number off of it. Sometimes there are manufacturers that have a ton of off brand (from China, most likely) replacements available (Drop-ins for your model number). You could pick one up (eBay?) and replace the damaged one.
Reply 13979 of 57996, by PhilsComputerLab
Guys I got a bit lucky 😀
On an Aussie forum someone linked an Asus VL/I-486SV2GX4 on eBay Australia. The price was decent, 60 Aussie dollars, so I bought it straight away!
I hope it all works out, but hopefully I got a decent VLB 486 board soon. There is good information and documentation from our VOGONS members about this board, so it should be good.
YouTube, Facebook, Website
