First post, by RaVeN-05
- Oldbie
Does its technically possible to raise CPU Hz to actual host OS ? or close to it? or much more Hz than it can have now?
What the problem? if we run dosbox on x86 or x64 architecure, so why not just make dosbox run on fly convert of 16 bit to 32 or to 64 by adding empty assemble instructions? what i mean
if we had AX (16) than add zeros and raise to EAX (32)
can instructions run on actual processor? everything need to be emulated for program sucessful startup, and to speedup run instructions on CPU directly? or by on fly convertor?
P.S. Another question, did DOS emulators or virtual machines exist with much more Hz of CPU?
