Reply 60 of 104, by FGB
OK, Bristlehog. Thanks! Will try the FF7 soundbank. Let's see or hear where it will take us.
//edit: The bank actually loads fine, but many instruments are missing or mute.
Another observation is that the drumkits seems to have too little volume, regardless which bank I load.
www.AmoRetro.de Visit my huge hardware gallery with many historic items from 16MHz 286 to 1000MHz Slot A. Includes more than 80 soundcards and a growing Wavetable Recording section with more than 300 recordings.
Reply 61 of 104, by bristlehog
Okay. I doubt that it's my hack that causes problems. After all, it only affects the 'mute aliases' which contain virtually no data.
Try testing the SF2 version. Also, upload your MIDI file(s) for me to test it against BASSMIDI synth with SF2.
If the SF2 version works ok (which might be not the case), then we have some serious problems with Awave WFB conversion.
Hardware comparisons and game system requirements: https://technical.city
Reply 62 of 104, by FGB
I will test the SF2 on a SB32 tomorrow but I fear it will sound alright.
Reply 63 of 104, by bristlehog
Ok. Here's another (now it's Advent GM): http://geryon.ru/advhack1.wfb
Reply 64 of 104, by FGB
And I thought Advent is still to come 🤣
//edit: Loads fine, but many instruments are sounding corrupted. Looks like the converter doesn't do its job well.
Reply 65 of 104, by bristlehog
You fell behind the times! You should spend less time tinkering... but hey, look who's talking!
Anyway, I tested Doom E1M1 against FF7 SF2 and some instruments are clearly missing:
http://geryon.ru/ff7doom.mp3 - rendered with FF7 soundfont
http://geryon.ru/tmbdoom.mp3 - rendered with Timbres of Heaven (360 MB in size) soundfont for comparison
Reply 66 of 104, by bristlehog
Fabian, try opening our converted WFB banks in WavePatch: are there any errors?
If you manage to determine which exact instruments are sounding corrupted, we might work something out by analyzing those instruments with Awave studio both in SF2 and WFB versions. If you can't, you still can record the audio so that I analyze it myself (probably by importing the MIDI file into a sequencer software, finding the notes corresponding to corrupt audio by timeline and reading through the MIDI stuff).
Reply 67 of 104, by FGB
I will do that tomorrow. Are you OK if I take the FF7 bank?
If you want I will analyse DOOM E1M1 and a Starwars or Warcraft Midi.
Reply 68 of 104, by bristlehog
I'm ok with that. Doom E1M1 and Warcraft sound fine to me.
Reply 69 of 104, by FGB
I will have to setup a whole "new" system for this project (in order wo load the WavePatch program and comare the SF2 banks properly.
At the moment I'm checking out the best specs. I think I will go with a P1 / PPro or P2 with Windows 95.
Reply 70 of 104, by bristlehog
Why Windows 95? I thought that Maui's drivers and software work best with Windows 3.1. Have you got another opinion?
Reply 71 of 104, by FGB
For me, 95 is much more convenient to use. If the stuff doesn't work I will stick to 3.1 of course.
Just don't know where to "buy" the time to build the system right now.. do you?
Reply 72 of 104, by bristlehog
Yes, I do. In the land of 'Think what you are doing all your 24 hours and why are you doing that and is it really so necessary to do it in the face of not having time for yourself and little things that fill you with anticipation'.
Reply 73 of 104, by bristlehog
My Maui arrived. It works, but MAUIDIAG reports a memory test error when both RAM slots are populated on the card. With just one stick of RAM, dependless on the slot it is inserted into, no memory errors occur. Did you see anything like this, Fabian?
1.99 MiB
Reply 74 of 104, by FuzzyLogic
I too got a Maui recently and I installed two 4MB sticks of RAM. I just ran the diagnostics and the memory tests (module 5?) all passed, but took forever. Did you try two different sticks of RAM?
Reply 75 of 104, by bristlehog
Yes, I tried different sticks of RAM. No matter what stick I use, if I populate both RAM slots, errors occur. If I populate only one slot, dependless of which one, first or second, no errors occur.
Perhaps I'll try 1mb sticks instead of 4mb ones just for the sake of experiment.
It might be that my Maui is defective, despite being new and unopened before me.
Reply 79 of 104, by bristlehog
I don't see any passives in bad shape.
I tested with 1 Mb sticks, and everything works fine, except for 2x4 Mb configuration. 1 Mb, 2 Mb and 5 Mb of RAM work. But when I stick in the 8 Mb, there are memory errors when running MAUIDIAG.
Perhaps I should check another type 4 Mb sticks (I have 4 of them but all of same type), problem is that I don't have any currently.
