Heatsink stuck to CPU
First post, by vladstamate
So last night one of my "older" PCs started overheating and blue-screening. It is a Phenom II X6. So I thought of removing the heatsink and fan and give it a good cleaning as well as replace the thermal paste. The problem is the existing thermal paste made the heatsink stuck to the CPU so when I applied some force the CPU came out of the ZIF socket even though the socket is closed (lever down). Now the computer won't start anymore. I checked the CPU closely and I do not see any missing or bent pins. I replaced the thermal paste, cleaned the fan but still nothing. The thing is even with this new thermal paste the cpu is still sticking so every time I take it out, it keeps pulling the CPU out of the socket 🙁 So questions..
1) What could be wrong?
2) I smudged some paste on the CPU pins and the socket, is that bad? Not too much.
3) How do I deal with the sticking heatsink other than getting a new one?
YouTube channel: https://www.youtube.com/channel/UC7HbC_nq8t1S9l7qGYL0mTA
Collection: http://www.digiloguemuseum.com/index.html
Emulator: https://sites.google.com/site/capex86/
Raytracer: https://sites.google.com/site/opaqueraytracer/
Reply 1 of 10, by kixs
You don't pull the heatsink but rotate it. Goes better when the CPU is hot.
There shouldn't be any paste on the pins. It might act as an insulator (depends on what's it made of).
Visit my AmiBay items for sale (updated: 2025-10-29). I also take requests 😉
Reply 2 of 10, by Jorpho
Yikes. I didn't think that was possible.
I wonder if you wrecked the socket?
Reply 4 of 10, by TheMobRules
kixs wrote:
It's possible and usually this isn't a problem.
Heh, that happened to me with an Athlon 64. The motherboard/socket was intact, but the CPU pins were horribly bent. I found quite surprising how little force it took to rip off the CPU with the lever down.
I now always lift the socket lever (if possible) when removing an old heatsink that seems stuck.
Reply 5 of 10, by vladstamate
I'll try to clean the CPU pins and the socket as much as I can. Rotating it seems like a good advice, not much space though. Also I cannot pull the level first as the heatsink is rather large and hovers over the whole socket.
Do you know of any methods to get thermal paste off? I just used paper towels.
Reply 6 of 10, by kixs
Paper towels are fine. Just use a little force and slowly remove the paste off.
Reply 7 of 10, by vladstamate
Well I fixed it in the end. After spending some time closely inspecting the pins I discovered one pin was bent and touching another pin. So I carefully straighten it and now the computer works again. Yay!
Reply 8 of 10, by FFXIhealer
I've received motherboards from manufacturers (for Intel LGA) where I had to inspect the array of spring contacts on the CPU socket for bent pins. Twice, I've found bent pins that I had to take a mechanical pencil (with the hollow metal tip) and straighten the pins out before I could install the CPU. I've fried a brand-new Core 2 Duo back in 2008 by not looking for bent pins first. Had to replace the MB and the CPU at the time. Now it's party of my computer build procedure - inspecting the CPU socket and the CPU itself.
Reply 9 of 10, by keenmaster486
You smeared thermal paste on the CPU pins?
I'm just trying to wrap my mind around this right now 😕
World's foremost 486 enjoyer.
Reply 10 of 10, by bbhaag
I had the same thing happen to me when I tried to remove the cooler from my Phenom2 965. I pulled instead of twisted and ripped that sucker right out of the socket hahha. Surprised me as well to say the least. Luckily I didn't bend any pins like you and everything went back together pretty smooth after I applied some AS5 and tightened down the cooler.
Glad you got it figured out and remember from now on twist don't pull! I know I'll never forget haha. 😀
