Reply 14240 of 58952, by SiliconClassics
- Member
wrote:I have a few systems with AGP Pro slots, one of which is a dual Athlon MP system that would work with the Wildcat II 5000 card (If I ever find another EATX case).
The Wildcat II 5000 can run on plain old AGP. If you've got a motherboard with AGP Pro, you can step-up to the Wildcat II 5110, which was the 5000's dual-piped big brother. It populates those empty solder pads with a second set of chips that increases performance in both single and dual-screen configurations. Some more info here.
