Reply 460 of 781, by clueless1
- l33t
wrote:This is next to impossible, as the PCI board has a different chipset, so it's hard to isolate just VLB vs PCI. I do have one Acer OEM board that has both, but I don't have a single card in both types 😀
The ET4000 would be great to compare ISA vs VLB vs PCI, but prices are out of control it seems.
Hold onto that Acer, in case you do get some more graphic cards 😀
Here's how I would approach it if you were attempting to compare PCI and VLB with two different boards: test the same ISA cards on both and if they are within 1% of each other on the ISA bus, then I would consider it a safe comparison. Just apply whatever difference there is on the ISA tests as a factor on VLB/PCI results.
