Reply 20 of 40, by Shogun
Ok I tried to load defaults. I don't have optimized - Just system defaults and no change there.
I then tried to change the DMA settings but I don't see anything related to the DMA in the bios. I've included screenshots of the relevant bios settings screens here.
I then realized the motherboard jesolo posted is close but the jumpers are off. I'm not sure how that site works exactly so I just did a search for 495SLC and found this: http://arvutimuuseum.ee/th99/m/U-Z/32085.htm
Its missing the chipset but the jumpers appeared all correct. According to what that sheet says and the jumpers I have stuff is all off? Like the battery is wrong - It says for NiCad which is what has always been in there to close pins 2 & 3 in jumper 29 but I have 1 & 2 closed which is for lithium. For CPU type configuration pins 12 and 14 match up with what the sheet says but jp15 should be closed for a 486 and on mine its open?
