First post, by dnewhous
- Member
Did any games like this exist?
Daniel L Newhouse
Daniel L Newhouse
SCUMM V5 non-talkie has it. Actually, it handles music and sound effects the same. All sampled sound effects have an Adlib alternative, which is used when playing in Adlib mode.
Games with Soundblaster support usually have Adlib only available for music.
Older games without Soundblaster support however frequently do have Adlib support as their best sound effects option. SCUMM V3 and V4 are among those.
DOS-PC: DFI k6bv3+, Pentium 200mmx, 64 MB RAM, Terratec Maestro 32 sound card, Roland MT-32 + SC-155, Winner 2000 AVI 2MB, Voodoo 1, Win98SE
Windows PC: GigaByte GA-MA790GPT, Phenom II X4 905e, 12 GB RAM, M-Audio Delta 44, NVidia 1060 6 GB, Win7 pro x64
Supaplex
The first Mortal Kombat also has some effects in Adlib mode. Not as rich as in SB mode, though.
Another World (aka Out of this World)?
F-15 Strike Eagle II or King's Quest IV, could you select Adlib for both sound and music on these games?
Daniel L Newhouse
wrote:F-15 Strike Eagle II or King's Quest IV, could you select Adlib for both sound and music on these games?
Not sure about the former, but based on the year of release, I strongly doubt that the game had any sound effects (digital voices).
The latter does not have any sound effects (digital voices). Any "sounds" you hear are purely generated from the FM synthesis chip.
It was also the first game that supported the Roland MT-32.
Commander Keen?
Test Drive 3 surely.
Duke Nukem II
Wolfenstein 3D's got a few adlib sound effects mixed in with its digitized sounds. I believe Falcon 3.0 does too. Bubble Bobble and Super Space Invaders are pure FM from what I remember.
Commander Keen 4, 5, 6, and Dreams (and mods/fangames based on these) all have purely Adlib sound effects and music. No digitized sound whatsoever.
World's foremost 486 enjoyer.
Doom
wrote:Did any games like this exist?
it depends on what you consider a "sound effect" - are we talking about PCM samples here? (for example, a .wav file)
The more sound cards, the better.
AdLib documentary : Official Thread
Youtube Channel : The Sound Card Database
Stunt Driver
Rise of the Triad allows you to use adlib for sound and have adlib sound effects
wrote:Doom
Blake Stone, Wolfenstein 3D, Commander Keen 4+ and games that use the same engine, such as Bio Menace, Dangerous Dave 2 and more.
Currently assembled vintage computers I own: 11
Most important ones:
A "modded" Olivetti M4 434 S (currently broken).
An Epson El Plus 386DX running MS-DOS 6.22 (currently broken).
Celeron Coppermine 1.10GHz on an M754LMRTP motherboard
wrote:wrote:Doom
More like an option of the sound library they used. Not exactly an option of the game, which has no Adlib sound effects included.
Interesting discovery nevertheless.
Sorry for necroposting, but Adlib can output digital sound, using more or less the same tricks as a PC speaker.
Exterminator (1990). Bit of an odd one, you can select Adlib or MT-32. If you select MT-32 you can switch in game between music or SFX, not both . If you setup with Adlib you get no music option and it is only used for sound effects. This game needs a patch to enable both MT32-music and adlib SFX option.
