Reply 14620 of 52794, by Carlos S. M.
wrote:Decided to get some XP era hardware while its dirt cheap and asked my dad if he could get me a decommissioned PC from his workpl […]
Decided to get some XP era hardware while its dirt cheap and asked my dad if he could get me a decommissioned PC from his workplace. This is what I got:
2GHz Celeron (Socket 478, not sure if netburst or northwood yet)
GF2 MX400
512MB DDR266
Sticker says it was manufactured in 2003Was missing the PSU which I couldn't fully replace due to the form factor (standard ATX works fine, just cant fit it inside the case), however the main thing I want from this is the motherboard - I'm planning on turning this into a 2003 beast with a Radeon 9800pro and a higher-end P4.
Sadly I'm unable to get much more info on the hardware now as the hardrive is making clicking noises and windows installation keeps freezing.
2 GHz Celeron is Northwood only, Your mobo should support similar FSB P4s, i don't know the motherboard model so i can't guess what is the fastet CPU supported
