Reply 14640 of 58933, by amnesia
It's time to start programming like its 197x 😉
The attachment programming_like_its_197x.jpg is no longer available
Also, a nice IBM - NOS/unused - keyboard.
The attachment 14991953_1663773360580668_7187324740827715688_n.jpg is no longer available
Lastly, I found a media for my newly acquired LS-120 drive. Where they all with lifetime warranty?
The attachment 15055873_1663795817245089_3705727788830838671_n.jpg is no longer available
Know where you came from to know where you're going
Reply 14641 of 58933, by keropi
got this nice 386DX/40 mobo:
for some reason it reports a "Cyrix M6 CPU"
mobo model is "364 v1.1" will try and locate it , battery damage is zero luckily
edit: bleh I can't find anything on it and there are some jumpers that I have no idea what they do 😵
Reply 14642 of 58933, by kanecvr
I have a similar mainboard, but with a ALi chipset. Online I found this - similar layout, sans the cache sockets:
http://th99.classic-computing.de/src/m/M-O/31690.htm
My board is labeled 386AD-III:
It's a little weird how your board sees the CPU as a Cyrix M6 😜
Reply 14643 of 58933, by stamasd
I'm going a bit crazy with upgrades to the Thinkpad 770Z.
Ordered a docking unit - the Selectadock III, and the Selectabase 770 which is required to connect the laptop to the dock. Surprisingly the Selectabase was much harder to find than the dock and almost twice as expensive. But with those on hand I will be able to transform this system into a little monster. The dock provides internal bays for devices (1 Ultrabay for Thinkpad-only devices, and a regular 5.25" bay), SCSI adapter with both internal and external connectors, USB hub and, best of all, 3 PCI and 2 ISA slots (2 pairs of shared ISA/PCI and 1 independent PCI). 😀
I think I'm about to build a "mobile" juggernaut here. I say "mobile" because the laptop by itself is barely portable (big and heavy), but with the base+dock it will become desktop-sized and over 15lbs total. 😀
I have some plans for those PCI and ISA slots... perhaps a TNT2+V2, or a V3 instead; and also an ISA sound card. Or just 2xV2 SLI using the internal Trident video... hmmm. There are also reports from back in 2001 that a V5-5500 PCI fits and works fine in this dock, but I don't have one.
Overall I'm pleased, and I managed to stay below $100 for the whole system (laptop+selectabase+selectadock).
(edit) Attaching the Selectadock III user's guide since it wasn't easy to find, for further reference
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 14644 of 58933, by nemail
luckybob wrote:
@nemail
Oh what a nice system! The sound card is a nice find! They are typically very rare! I'd say the sound card alone is worth more than what you paid for everything.
There are MANY, MANY quirks of this system. If you ever need some 1 on 1 advice, hit me up. I have 3 of these machines and I like to think I know them well. the reference disk mentioned is available here: http://www.ibmfiles.com/ps2disketteimages.htm error codes are here: http://www.tavi.co.uk/ps2pages/ohland/error_02.htm
Thanks for that offer, actually I think I'm gonna need you already 😁
When the Audiovation card is installed, it said that it needs the ADF so I installed the "option disk", rebooted and ran the automatic configuration.
but after that, it still reports an error and says that I have to run the tests, if I didn't install or uninstall any cards.
when I pull the audiovation card out, it immediately boots to a Windows 95 installation.
errorcode is always 16500 (if audiovation is installed)...
Reply 14645 of 58933, by TheAbandonwareGuy
Ok. I've actually had this system for a week but mental health issues have kept me from posting about it.
It's a Compaq Deskpro EN with a 933MHz PentiumIII (according to the start up console for American McGee's Alice it's a Copper mine), 128MB PC133 SDRAM (Expandable to 512MB via 3 DIMM slots), Intel PremierSound (which only provides DOS Audio under Windows 98's DOSBOX @ channel settings 5-1-5, if I restart into DOS mode I can't get anything to detect audio. I suspect I'm short a driver, anyone got any suggestions?),
Standard 3.5 Floppy, and a 52x CD-ROM. It's currently running Windows 98 Second Edition. I have the missing piece to the front panel as well.
The entire inside of the case smells like mold. Nothing visible and she runs solid though. The motherboard is an i820 Socket 370 with 5 PCI and 1 AGP. The case is ATX but the motherboard is somewhere in-between ATX and mATX. The AGP is unkeyed Universal which is nice meaning I can run anything from a RIVA128 to a 7800GS in it.
Currently I've installed some networking cards, my ASUS Falcon2 TV Tuner, and a Jaton Geforce2MX 32MB PCI. I plan to get a Geforce2GTS, a DXR3 DVD Decoder (along with a DVD Drive), and a Soundblaster128 for this system since those were the parts listed as "top" for this model in the OEM PDF files. I may also go for a 1.4GHZ Tualatin. I'm not sure if this motherboard would accept it though. It's also probably worth it to upgrade the memory to 256MB.
On board sound is really Skippy along with the flaky DOS audio. Not sure if it's the drivers or the hardware. Either way once I get the SB128 hopefully that fixs all of the above. Still if anyone has any suggestions for the PremierSound I'd love to hear them.
Reply 14646 of 58933, by stamasd
keropi wrote:
got this nice 386DX/40 mobo: […]
Nice late 386 motherboard. I have about 3 with this type of layout, (one 386SX, one 486DLC and one 486SX). Good luck finding information of them. Many are known to have fake cache chips (one of mine does) but since your cache is socketed there, the chances of that are low.
Here's a discussion of my motherboard with fake cache (I am jh1523) http://www.vcfed.org/forum/showthread.php?430 … ight=fake+cache
I/O, I/O,
I/O, I/O
Reply 14647 of 58933, by keropi
^that pic you posted over at VCF is mine 🤣 , I still have the BIOTEQ mobo
Reply 14648 of 58933, by stamasd
And so after a few years the circle closes. 😀
I/O, I/O,
I/O, I/O
Reply 14649 of 58933, by kithylin
TheAbandonwareGuy wrote:
Ok. I've actually had this system for a week but mental health issues have kept me from posting about it. […]
Just a suggestion.... but.. if you resized your pictures to fit into the forums, we could actually see them.. 😁
Reply 14650 of 58933, by luckybob
Or just buy a bigger screen.
Reply 14651 of 58933, by TheAbandonwareGuy
I thought I did. Im on mobile, imgur upload must have messed up. Oh well, there only 26 megapixel
Reply 14652 of 58933, by luckybob
*They're
Reply 14653 of 58933, by debs3759
SW-SSG wrote:
debs3759 wrote:
More accurately, all Celeron on socket 478 have Northwood-128 core. ...
Incorrect! There are s478 Willamette-128 Celerons also.
I stand corrected 😀
SL68F is a 2.0 GHz Willamette-128 Celeron
Reply 14654 of 58933, by kithylin
I'm already on 1080p screens everywhere, that's the standard today. Everything should at least fit that.
Reply 14655 of 58933, by debs3759
Kamerat wrote:
...and Prescotts: https://en.wikipedia.org/wiki/List_of_Intel_C … .22_.2890_nm.29
In my post I also said
Celeron D are Prescott-256. Both are built around the Netburst architecture.
Celeron by another name 😀
Reply 14656 of 58933, by TheAbandonwareGuy
Those images wouldn't even fit on a 4k screen in Fullscreen mode. There slightly larger than that.
Reply 14657 of 58933, by James-F
I'm building another Socket 7 machine.
PC Partner 35-8333-04, Intel 430TX:
The attachment S7mb.jpg is no longer available
I'm also modding one of these to include -5v using a LM7905.
The attachment atxtoat.jpg is no longer available
I also bought a bunch of related stuff like heatsink, fan, USB PCS cards, USB header bracket, Serial+Parallel Bracket, PS/2 to AT adapter, and more.
I already have CPUs, video cards, sound cards, network card, HDD, CD-ROM, to choose from.
One can't have enough Pentiums, don't you know? 😎
Reply 14658 of 58933, by keropi
^ do search the USB header pinout of your mobo James-F - back then the pinout was not the same as now , 1 port will work fine but the other will need to have the pins reversed (so no matter how you plugged the header it would work OK). Needless to say that with the current pinout one port will be reversed and I have no idea if it can cause damage or not...
Reply 14659 of 58933, by James-F
Thanks keropi.
Actually, I have the exact same board in my current machine but rev 01 (this one is 04), and on the PC PARTNER website they still have all the Manuals, Bios updates, header pinouts, and jumper configurations, very well documented and reliable Socket 7 board.
It also has low thinking noises, which is important for me as I fancy sound cards mostly.
