DreamBlaster X1 : a rare card
Reply 21 of 67, by gdjacobs
The RPi2's UART can be configured to function as a MIDI interface and has plenty of power to run a wavetable engine or Munt. No dangling wires, just normal MIDI cables (or potentially an internal ribbon cable).
Reply 22 of 67, by GuyTechie
I have an X1, and I love it! I didn't realize how little you sold. Glad I got it over the S1. 😀 Still loving it.
Reply 23 of 67, by Jorpho
I presume connecting to the wavetable header causes fewer compatibility problems than an external MIDI interface.
Reply 24 of 67, by gdjacobs
I don't think it matters much.
Reply 25 of 67, by PhilsComputerLab
A quick look at a prototype of the X2. Anything is subject to change, so keep that in mind. I've also done two quick recordings of Doom and Descent Setup.
It's smaller, so fits without issues on Audician 32 Plus and ESS cards.
I used the ESS card shown below to record the two songs.
YouTube, Facebook, Website
Reply 27 of 67, by gdjacobs
Programmable via USB?
Reply 28 of 67, by PhilsComputerLab
I'll let dreamblaster answer any questions about this product 😊
Reply 31 of 67, by gdjacobs
You tease!
Reply 32 of 67, by dreamblaster
X2 is plug an play as waveblaster module on your soundcard, no need for any setting. It is preconfigured with a high end dream General MIDI bank.
USB functions :
- USB-MIDI : plug it in a modern pc and use as midi synth module as well, it will pop up als Dreamblaster X2M (X2 Module) MIDI device
- Upload of soundbanks in dream binary format. X2 has 64 mbyte of flash, 63.5mbyte can be used for soundbanks. High end piano bank planned (working on this).
- Upload of presets : for persistent configuration of various parameters (working on this)
Thanks for your support !
Reply 34 of 67, by gdjacobs
dreamblaster wrote:
X2 is plug an play as waveblaster module on your soundcard, no need for any setting. It is preconfigured with a high end dream G […]
USB functions :
Do you have a recommended pipeline for converting from SF2 to Dream format?
Reply 36 of 67, by Munx
USB functions :
My builds!
The Underdog - The budget K6
Reply 37 of 67, by CHiLL72
I suppose I can put up a few pictures of the X2 prototype that I received on my webpage now 😀
Tested the X2 prototype board on Serdaco's Waveblaster MIDI interface (highly recommended) and on a Diamond MX300 as well as the direct USB connection of the X2. Preliminary test results are very positive, keep an eye for this one!
Waveblaster MIDI boards: https://waveblaster.nl - online now!
Reply 39 of 67, by Kodai
I'm thinking I'll get two or three myself.
