First post, by MasterShadrack
MasterShadrack
Offline
I was looking into using my G5 to run old games. By looking at the source code, I noticed that Endianess is handled with bit-shifting operations. However, the PowerPC architecture, from the beginning, supported Endian correction instructions. I changed "include/mem.h" to handle this particular case. I tought that an DosBox developper could integrate it into the product. Here my little modifications:
#ifdef WORDS_BIGENDIANINLINE Bit8u host_readb(HostPt off) {return off[0];};INLINE Bit16u host_readw(HostPt off) {#if defined(__ppc__) && defined(__GNUC__)unsigned long result;__asm__ volatile ("lhbrx %0, 0, %1"/* outputs: */ : "=r" (result)/* inputs: */ : "r" (off)/* clobbers: */ : "memory");return result;#elsereturn off[0] | (off[1] << 8);#endif};INLINE Bit32u host_readd(HostPt off) {#if defined(__ppc__) && defined(__GNUC__)unsigned long result;__asm__ volatile ("lwbrx %0, 0, %1"/* outputs: */ : "=r" (result)/* inputs: */ : "r" (off)/* clobbers: */ : "memory");return result;#elsereturn off[0] | (off[1] << 8) | (off[2] << 16) | (off[3] << 24);#endif};INLINE void host_writeb(HostPt off,Bit8u val) {off[0]=val;};INLINE void host_writew(HostPt off,Bit16u val) {#if defined(__ppc__) && defined(__GNUC__)__asm__ ("sthbrx %0, 0, %1" :/* inputs: */ : "r" (val),"r" (off)/* clobbers: */ : "memory");#elseoff[0]=(Bit8u)(val);off[1]=(Bit8u)(val >> 8);#endif};INLINE void host_writed(HostPt off,Bit32u val) {#if defined(__ppc__) && defined(__GNUC__)__asm__ ("stwbrx %0, 0, %1" :/* inputs: */ : "r" (val),"r" (off)/* clobbers: */ : "memory");#elseoff[0]=(Bit8u)(val);off[1]=(Bit8u)(val >> 8);off[2]=(Bit8u)(val >> 16);off[3]=(Bit8u)(val >> 24);#endif};#define MLEB(_MLE_VAL_) (_MLE_VAL_)INLINE Bit16u MLEW(Bit16u val) {
#if defined(__ppc__) && defined(__GNUC__)unsigned long result;__asm__ volatile ("lhbrx %0, 0, %1"/* outputs: */ : "=r" (result)/* inputs: */ : "r" (&val)/* clobbers: */ : "memory");return result;#elsereturn (_MLE_VAL_ >> 8) | (_MLE_VAL_ << 8);#endif};INLINE Bit32u MLED(Bit32u val) {#if defined(__ppc__) && defined(__GNUC__)unsigned long result;__asm__ volatile ("lwbrx %0, 0, %1"/* outputs: */ : "=r" (result)/* inputs: */ : "r" (&val)/* clobbers: */ : "memory");return result;#elsereturn ((_MLE_VAL_ >> 24)|((_MLE_VAL_ >> 8)&0xFF00)|((_MLE_VAL_ << 8)&0xFF0000)|((_MLE_VAL_ << 24)&0xFF000000));#endif};#else// Little-Endian empty translators#endif
I played my old KQ3 games with those modification without any noticable bug. Hope that help.
