DOSBox LOVE Edition (for OSX/macOS)
Developer's Forum, for discussion of bugs, code, and other developmental aspects of DOSBox.
Postby Crosma » 2016-11-27 @ 04:13
I created a DOSBox fork because I had a lot of difficulty getting Glide working with existing builds. It also has fixed high bitdepth support. I also packaged it up into an app bundle.
It's based on newish master branches of DOSBox and OpenGLide. I used some patches I found here and made some additional changes.
You can download it here (source and binaries):
http://crosma.com/software/dosboxlove.tar.bz2
User avatar
Crosma
Re: DOSBox LOVE Edition (for OSX/macOS)
Postby IIGS_User » 2016-11-28 @ 15:57
thank you very much for this port.
Just a msg to other readers:
After downloading, I discovered it requires macOS (OS X 10.12),
but will not run on older versions of OS X (10.11-),
which is installed on "my Mac" currently..
Klimawandel.
User avatar
IIGS_User
Postby Crosma » 2016-11-30 @ 09:54
I've still got a 10.9 install around, so I should be able to put together a build on that.
User avatar
Crosma
Postby Dominus » 2016-11-30 @ 11:10
no need to build it on 10.9, you just need the correct deployment target set (for Dosbox and all the libs)
User avatar
Dominus
DOSBox Moderator
Postby IIGS_User » 2017-1-29 @ 20:21
As a DOSBox front-end programmer in hope to add support for it, I must ask the following question:
Is the config file fixed to "~/Library/Preferences/DOSBox LOVE Preferences" or can the standard one also be used to feed DOSBox Love Edition?
Klimawandel.
User avatar
IIGS_User
Postby Crosma » 2017-10-11 @ 09:32
IIGS_User wrote:As a DOSBox front-end programmer in hope to add support for it, I must ask the following question:
You should be able to feed it via. command-line parameter or whatever.
User avatar
Crosma
Postby IIGS_User » 2017-10-11 @ 16:04
Thank you for the comment.
With Daum build, which also uses its own config file, I let my frontend edit its orginal config file, leaving an original copy around.
Still not implemented yet, but I think I would work the same way with your port.
Klimawandel.
User avatar
IIGS_User
Return to DOSBox Development
Who is online
