First post, by chinny22
- l33t++
I started replying to this thread re OEM machines but thought rather then hijack it I would start a new thread.
Re: Dell Precision 380 (Pentium 4 workstation)
OEM PC's seem to bring out a hatred in people I never really understood.
My first 2 PC's were OEM I suppose.
First was a 486 from an Australian company (Osborne Australia) that used mostly generic parts, but built to such a volume that it was standardised.
came with high speed serial ports (important during the dial up modem days), PS2 connectors well before either were the standard and just ran
Where as my friends PC built at a local IT shop had none of the above and had nothing but problems.
Few years later I got my own PC (Gateway P2 400) parents got a Celeron 500 1 year later from a different local shop based on a Asus-P2B-ZS motherboard.
Again the Gateway just worked, Even after I stole the SBLive! form the Celeron. (and now straying from the "official Gateway build"
Where as the Asus just never seemed to run smoothly.
I put it down to big brands have to have R&D to ensure that all the parts work well, which as a bonus means there is a good chance upgrading other parts still wont have any negative effects.
Smaller companies cant do this as their hardware list will change from month to month depending on whats in stock, or special. So will only find out about incompatibility's if and when they happen.
OEM's are often criticised about their lack of BIOS options.
I'll admit sometimes they seem to go a bit far, but again it comes to reliability. Overclocking, memory timings, these things affect reliability and that's what you are paying for with an OEM.
OEM's are not perfect, gimped hardware like soundcards, non standardised connectors for no good reason are the first 2 that come to mind.
I also find systems built for the workplace are far superior to their home market range
Just interested in why some people have such a strong opinion. I also have PC's built with Generic parts, yes they run fine, but often needed to make a compromise with some bit of hardware that didn't work with the rest of the system or physically fit, yet I don't HATE generic hardware
