Reply 20 of 30, by badmojo
The DOS software for that card is pretty shite, maybe the Win 3.11 drivers where likewise neglected? It's more of a Win9x era sound card in my mind.
Reply 21 of 30, by mrau
what changes to system ini did the installer do? especially that mentioned file, where does it reside? any info from docs what it does?
Reply 22 of 30, by feipoa
It does seem more like a Win95 era card. Are there some other drivers you recommend?
Reply 23 of 30, by badmojo
No I don't I'm sorry - I've tried a couple of different versions to see if there's a better version for DOS but they're all pretty much the same.
For a nice sound experience in Windows 3.11 I go with a PAS16, which has fantistc software.
Reply 24 of 30, by feipoa
I looked those up on eBay - they are $100? Jeez! Not really worth it for just a test bed. My regular system has an ESS AudioDrive, which is fine enough. I am just wanting to run some tests with various DLC/SXL CPUs and various motherboards w/SCSI and sound to determine what the limitations are for each motherboard in this regard. I have an AWE64 Value I could try instead. There's also a vibra or two hanging around.
Reply 25 of 30, by boxpressed
This thread shows how you can use Mediatrix software with the YMF71x cards to initialize:
YMF-71x cards (OPL3SAx) software alternative
Reply 26 of 30, by feipoa
Isn't that only the DOS drivers? My issue is with the Win 3.11 drivers. I can use the Audican32's DOS drivers in DOS.
Reply 27 of 30, by feipoa
I abandoned the YMF718-S for a Vibra16, which is good enough for a test bed. All systems go. Not sure of the cause of the Audican's incompatibility with this board.
Reply 28 of 30, by terryfi
For those who still looking for solution, I followed the instructions on this page and it fixed the issue:
https://support.dynabook.com/support/viewCont … ontentId=107632
It seems that Yamaha software GM driver in Windows and Windows network stack overlap in some address range and can't get along.
So the trick is to disable soft GM.
I even had this issue with 36 MB of RAM. Memmaker didn't help neither disabling EMM386 .
Reply 29 of 30, by feipoa
terryfi wrote on 2021-10-08, 01:14:
For those who still looking for solution, I followed the instructions on this page and it fixed the issue: https://support.dynab […]
Thank you. The information in that link would have the user do the following within the system.ini file:
1) delete DEVICE=VSGM.386 [I think you can also comment it out with a semicolon ;]
2) change CPLMPUBoth=0 to =1
3) change DelSoftSynth=0 to =1
Indeed, this let me boot into Windows 3.1 with my SXL2 and an Audican32 card, however I was unable to play a wave file. Simply no sound comes out of the speakers and no error is produced. On the other hand, midi files play fine. Did you run into this problem?
Reply 30 of 30, by terryfi
As far as I remember I did not run into any other problems. I was able to play MYST with working audio and video.
feipoa wrote on 2022-09-29, 07:56:
Thank you. The information in that link would have the user do the following within the system.ini file: […]
