Reply 580 of 5269, by Deksor
I've got an HP vectra with a 486 DX 33. I remember that I used a DX2 66 at some point and it worked without any problems. The only problem with that machine is that the bios doesn't support LBA (but this happened also on regular boards) and maybe also the fact that I can't touch any of the timings, but it's still a fast 486 I think. I wonder what could be done with it if we had an old version of AMIBCP.
I've seen far worse custom built computers on the opposite (cheap PCChips stuff for example)
Reply 581 of 5269, by Kadath
brostenen wrote:
Well.... I kind of like that HP 4/100 machine.
HP and IBM are my favorite brands from that era, yet nothing beats a good home build machine.
I totally agree to that, brostenen - I would be sorry to throw away this machine, after I've found that - I'm sure it will be a nice machine, over all.
Me too - mine is a 486 DX-4 100, this could be lucky Vectra findings week 😉
I recently found this hardware, AKA the Dumpster find thread.
First comes smiles,
then lies.
Last is gunfire.
Reply 582 of 5269, by Kadath
Here you are the another machine I've rescued, a TX-based build, with Pentium 100mhz + heatsink, 32MB SIMM RAM, S3 Trio32 - it had a 24x broken CDRom, that I've changed with a working 52x. I swapped the Trio 32 with a Trio 64+ (although there are 2x free memory sockets), and mounted a Creative AWE64 non-Gold for audio section. For the storage, I've mounted a Quantum LCT 15GB, although BIOS can only see 8GB, LBA - I don't have any other little-sized hard disks - must buy other IDE2CF adapters. Now the system is fully working, but I've to change the way front display show real clock, because it shows 16 instead of 100.
First comes smiles,
then lies.
Last is gunfire.
Reply 583 of 5269, by James-F
I scored 3 Pentium II from the college attic.
ASUS P2L-B motherboard, 266MHZ PII, ATI Rage AGP, Intel LAN, SB16 Vibra16XV in all of them.
Don't care much about P2 but the AT cases and power supplies are worth it.
Reply 584 of 5269, by c0keb0ttle
Nice!
Yellow, yellow-er, and yellow-est! 🤣
Also known as "spot the computer from the smoker's office".
Reply 585 of 5269, by James-F
Heh. 😁
I wonder if they'll make a good 90s era DOS machines like my beloved Pentium 1 233MMX.
Reply 586 of 5269, by PcBytes
Kadath wrote:
I've got 3 machines, this afternoon - 1x Pentium II build, on usual BX-440 - motherboard not branded, it seems something like ASUS P2B-F but without name. The Pentium II found aboard is a 300mhz model.
A Google search told me that motherboard is made by A-Trend.
Reply 587 of 5269, by kanecvr
c0keb0ttle wrote:
Nice! […]
Nice!
Actually direct sunlight that turns white plastic yellow, not cigarette smoke - it has to do with flame retardant compounds mixed in with the plastic. All cigarette smoke will do is make it smell bad and give it a light yellow tint that washes off. I tough this was common knowledge by now, what with retro-bright and all.
Reply 588 of 5269, by Deksor
I heared that yellowing was a reaction between oxygen and like you said, flame retardant, not light, but I think that light and heat are accelerating factors for that reaction, wich explains why some computers that spent all their life in darkness can sometimes turn yellow (I've heared that was happening too) and that's why after a retrobright people sometimes put something more on their plastic in order to private it from oxygen
I've got one AT case with what looks like to be the same interior, and I've seen at least two other AT cases with different front but still the same interior. But they were also all very fragile because they tend to bend easily. Is it the case for you ? Looks like somebody was building pretty cheap cases and then whoever wanted to use them had to put their plastic front on the cheap metal
Reply 589 of 5269, by brassicGamer
Saved this machine from the skip at work only because of the name and because I thought it was a Pentium II.
The attachment 20161206_140036-1200x2133.jpg is no longer available
Would have made a good replacement for my dead Dell GX1. Not so happy to find out it's actually a Pentium III 800 with some ATi Rage and i815 chipset. Keep or put back in the skip?
Reply 590 of 5269, by Carlos S. M.
Keep for some other use, maybe you might need it someday
Reply 591 of 5269, by sirlemonhead
I love Gateway machines, I'd certainly keep it myself...
Reply 592 of 5269, by brassicGamer
So, the same reason I keep all my crap, then? 😉
Sure, I'll keep it. It's nice to have a selection of OEM machines. This one isn't exactly a classic, but until a Gateway 2000 comes along it's the only Gateway I've got. It'll go next to the IBM and the Dell. Somewhere...
Reply 593 of 5269, by JidaiGeki
I've got a 650MHz unit that someone painted to look a bit more festive ...
The attachment GATEWAY.jpg is no longer available
Had to replace the PSU, that wasn't cheap ...
With the 815 you'd be able to put maybe a 1GHz CPU in? Could be paired with a better PCI graphics card, or even V2 SLI, though you'd need better cooling in either case. It's a nice little system, so it would be a shame to scrap it (again).
Reply 594 of 5269, by Ariakos
I got this IBM Thinkpad 600E (with carrying case, PCMCIA WLAN card & external floppy drive!) as a giveaway. It has lots of scratches & dents. The docking port especially is little bent (probably fixable, though). Despite the rugged looks it works perfectly. Awesome! 😎
Reply 595 of 5269, by James-F
Thickest layer of gunk around the touchpad I've seen in a while.
Better wash your hands real good before eating.
Reply 596 of 5269, by brostenen
Found something nice today, though way too new for my collection as such.
It will go into my mame machine, that I am in the process of making.
(7/8 years in the making, because something else keeps comming up)
This is one of the two I found today. As they are identical, only one pictured.
The attachment 2GB-DDR2-01.jpg is no longer available
The mame machine will be:
- P4 Socket 775 3ghz
- 5gb Ram (2x2gb + 2x512mb)
- Radeon x550 64mb PCI-E
- 80gb SATA-II HDD
- DVD rom
The fronend will be Maximus Arcade, butt-load of emulators and 80's pop-hits
playing as background music when in the gameselect-menu.
Reply 597 of 5269, by brostenen
c0keb0ttle wrote:
Nice! […]
Nice!
Nope... Not nichotine. Nichotine will leave a easy to clean reddish-brown colour instead.
People are so afraid of tobacco, and it has become something so evil, that people start
thinking that it does more than it really does.
Nicotine is actually an oil from the plant. It is also a natural insect poison.
In the 1940's, during WWII, we tried to use it as a insectiside, because of scarse raw materials
for the chemical industry.
And because tobacco was not being inported in those 5 years of time, it was grown in denmark.
My grandfather had a fruit farm, and he grew tobacco alongside fruits and berries.
Plus he rolled cigars, that he could sell too.
Deksor has given one of the factors to why. It is the flame retardent's.
They react to both uv light, heat, oxygen and other things.
More or less a chainreaction of event's that can turn the plastic yellow, at a slow or fast rate.
This is why we use that nasty peroxid in a more consentrated level than the one for disinfection.
The exact chemical reaction I do not know. I have not even read as to why exactly that is.
Probably just a case of "it just works, so we do not bother knowing why".
Or is there a more in dept answer to this?
Reply 598 of 5269, by Brickpad
Those are some spiffy looking cases. De-yellowing the one of the right shouldn't be too hard.
Reply 599 of 5269, by King_Corduroy
Found these guys last week! Probably not going to keep the HP Pavillion but man that Commodore monitor is MINE FOREVER. 🤣
Check me out at Transcendental Airwaves on Youtube! Fast-food sucks!
