Kadath wrote:Cool case - I like professional-line server case, this beauty will last forever
I'm sure it will, It's build like a tank.
keropi wrote:@kanecvr
awesome Chieftec case mate, I really like it... it's model is UNI or MESH os something like that AFAIR... Chieftec used the same metal chassis in many full tower cases and they only changed the front faccia depending on the design. I wanted to get this one ~10 years ago for my main pc but I had to settle for the CHIEFTEC GIGA GX-01B-OP model that was in stock back then and I still use on my main pc - the insides changed many times but the case remained the same 🤣
Thanks! I've been looking to get one of these for a while now - I also like it's stilling, and the metal bits are of excellent quality. The plastic is "meh" - above average I'd say. Back in the day, these were "the" high-quality case to get for your expensive build, even tough it wasn't a server or workstation 😀
brostenen wrote:
Nice case. It looks like a sweet one with lots of potentials.
How thick are the plates in it?
Believe it or not, it's about 1.5-2mm thick and it weighs a ton!
Aideka wrote:The PSU is pretty much absolutely fine, as long as the caps are in working order, AFAIK it uses CapXon caps, so they might blow, but if you pull under 500 watts from it I would not worry.
luckybob wrote:The corsair supplies are very good. You eont have any issues with them.
I sure hope you guys are right, but time will tell 😀 For now it seems to be working fine.
Jade Falcon wrote:luckybob wrote:The corsair supplies are very good. You eont have any issues with them.
I seen 100's of dead corsair supplies on ebay.
Some are good and some are not.
Same with any manufacturers unfortunately. What has me worried is that this PSU belongs to their "value series". I know vs ram is good, hoping this PSU is decent.
