"Strix", My ASUS based Socket 7 System.
Showcase your Retro PC / Build logs.
Postby Hellistor » 2016-12-11 @ 22:49
Hello,
This is my newest build.
I aquired this system at the same time as my AM486. High resolution pictures can be found here
It features:
Motherboard: ASUS P/I-P55T2P4 Rev 3.10
CPU: Intel Pentium-S 133MHz
RAM: 32MB 60ns EDO RAM
Cache: 512KB Onboard (64MB RAM Cachable)
Graphics card: S3 Trio64V+ 2MB
Ethernet: 3Com PCI Ethernet Card
Soundcard: Soundblaster 16 CT1740 DSP 4.05
HDD: 5GB Quantum Fireball
CD: ASUS 40xMax CD Drive
Floppy: 1.44MB 3 1/2' Drive
Midi Module: Roland MT-32 (OLD)
Peripherals:
PS/2 Mouse: Microsoft Intellimouse 1.2A
USB Mouse: Logitech G5
Joystick: Microsoft Sidewinder 3D Pro
Keyboard: IBM Model M
Mousepad: Steelseries QcK
Monitor: Fujitsu Siemens C775
Speakers: NEC Stereo Speakers
It is running Windows 98 SE with an adapted version of Phil's DOS Starter Pack.
I'm using SoftMPU for the MT-32. This card needs the /SBMIDI and /DELAYSYSEX switch to work in Strike Commander.
Here's an inside view.
Expansion cards.
Rear I/O
Here we have Age of Empires running in Windows.
This is Descent 2 running under Windows using the Sidewinder 3D Pro.
Under DOS this machine is quite capable, it's running Duke Nukem 3D at 640x480 decently.
Doom 2 is also great.
Strike Commander is wonderfully smooth on this machine.
Now, you may have asked yourself what all the CPUs on the Keyboard are for.
If you would like to see another CPU in this machine you can pick from these. I originally made a strawpoll but that doesn't quite work, so just post in the thread what you want me to use.
I hope you enjoy the machine!
User avatar
Hellistor
Re: "Strix", My ASUS based Socket 7 System.
Postby Hellistor » 2016-12-11 @ 23:39
Reserved for Updates.
I removed the Strawpoll. It doesn't quite work as I thought it would. For example it doesn't let you change your vote afterwards.
Also I removed the Pentium MMX CPUs as Options as I already have a System with one of those.
Feel free to voice your opinion on which of the CPUs shown above I should use!
User avatar
Hellistor
Postby gdjacobs » 2016-12-12 @ 01:07
I'd love to see the P54 running for some SETMUL test register benching. How smooth does it slow and how slow does it go?
User avatar
gdjacobs
Postby Hellistor » 2016-12-12 @ 01:23
gdjacobs wrote:I'd love to see the P54 running for some SETMUL test register benching. How smooth does it slow and how slow does it go?
That's actually a good idea! As soon as I have time I'll get SETMUL running and run some benchmarks with Phil's DOS Benchmark collection.
I can tell you though that disabling the caches in the Bios results in good slowdown. Ultima 6 for example runs pretty well.
User avatar
Hellistor
Postby gdjacobs » 2016-12-12 @ 05:44
Absolutely. I'm curious if it can do intermediate speeds.
User avatar
gdjacobs
Postby foey » 2016-12-12 @ 12:32
Very nice build.
How do you find the 40x CD-ROM? I had a 48x Compaq drive in my P133 rig and had to try to reduce the speed due to noise. I managed to set it to 4x in DOS but had trouble in Windows. I later picked up a quad speed CD-ROM which is much better - no more hair dryer!
Cyrix Instead Build, 6x86 166+ | 32mb SD | 4mb S3 Virge DX | Creative AWE64 | Win95
ATC-S PIII Tualatin Win9x Build :- http://www.vogons.org/viewtopic.php?f=25&t=40248
User avatar
foey
Postby Hellistor » 2016-12-12 @ 12:55
foey wrote:Very nice build.
Thank you! It was fun building it.
Well with the CD drives I have a "whichever works" attitude. I try to get something that doesn't look out of place but other than that I'm not concerned much buy noise and such.
I used this one because it's an ASUS drive and I like pairing it with the ASUS motherboard.
User avatar
Hellistor
Postby foey » 2016-12-12 @ 13:06
The trouble I found with quicker drives was one the noise and two the constant spinning down (Big latency for older games) The older drives, 2-12x were much quicker to spin up. Just wondered if you had any issues.
I just replaced my Cyrix 6x86 for a Pentium 133mhz like yours and found it to be all round quicker. It's very close to what I had back in the day now.
http://www.vogons.org/viewtopic.php?f=25&t=45740
Love your case :)
User avatar
foey
Postby Hellistor » 2016-12-12 @ 13:32
foey wrote:The trouble I found with quicker drives was one the noise and two the constant spinning down (Big latency for older games) The older drives, 2-12x were much quicker to spin up. Just wondered if you had any issues.
That makes sense, I noticed long loading times from the CD, but I don't really mind to be honest.
foey wrote:I just replaced my Cyrix 6x86 for a Pentium 133mhz like yours and found it to be all round quicker. It's very close to what I had back in the day now.
That looks like a nice machine! I really like Desktop cases.
foey wrote:Love your case :)
Thanks! I think it fits with the "ASUS Theme" for some reason. That's why I called it Strix.
User avatar
Hellistor
Postby Tetrium » 2016-12-13 @ 13:56
My 40x CDROM drive was very noisy as well (not sure about brand, but I don't think it was ASUS). I think it starts getting a bit better below, say, 30x or so.
User avatar
Tetrium
Return to System Specs
Who is online
Users browsing this forum: Turbo -> and 5 guests
