Reply 20 of 25, by raymangold
 - Member
wrote:Hello everybody, […]
Hello everybody,
If somebody knows, where I could buy a PowerLeap PL-K6-III, or if somebody will sell this adapter, please send me a private message!! I would need it for an Socket 7 IBM PC.
Thanks,
KH
It took many years for me to find one and then I had to buy the K6-III separately. Try looking in Japan or Germany. Those two places keep things like this longer than the rest of the world. I don't know if the PC 750 will work well with a K6-III or not. At any rate, most of the collectors have snapped these up and everyone else has since recycled them.
wrote:raymangold, what chipset are you using on that motherboard? And did you try a K6-III in the socket directly? If your motherboard's BIOS can be modified to accept a K6-III or II/III+, would there be any benefit to this Powerleap adapter? Jan S. modified the BIOS of my 430TX-based motherboard and it runs great with K6-III+ CPU directly in the socket. I took it up to 500 MHz (6x83) w/256 MB and it is surprisingly stable.
I didn't see this thread being resurrected--
This is a Triton II chipset, the BIOS never had to be modified to accept a K6-II, since the Y2K update added AMD CPU support. I'll just quote the sections from the manual and BIOS change log for posterity:
PC 300PL computers use IBM power-on self-test (POST) software with initialization code added for the
Intel Pentium processor with MMX technology, the Intel 82430HX core chipset, the National
Semiconductor PC87307 I/O chip, the Intel Ethernet chip, and the Matrox MGA-1164SG 3D video chip
PC 300PL computers have an Intel Pentium processor with MMX technology. This microprocessor has separate core supply (2.8 V) an […]
separate core supply (2.8 V) and I/O supply (3.52 V) voltages. A voltage regulator on the system board
converts the 3.52 V provided by the power supply to the core voltage (2.8 V) required by the
microprocessor.
Flash Changes Model 6562 6592 NMJTxxA is the flash diskette level. NMKTxxA is the flash image level. Add support for AMD 233MHz […]
Add support for AMD 233MHz processor.
This isn't a super socket 7 system, so it feeds the CPU's vcore with 2.8v. The K6-III and other CPUs operate on less voltage (2.2v and others even lower). I mean, one could try and the CPU would probably work for a few seconds before frying--or worse blowing out your VRM. The PowerLeap does need to be configured for the appropriate voltage for the corresponding CPU; and the lowest it can go is 2.2v.
I COULD modify the VRM that's present on the motherboard itself to supply the CPU with 2.2v instead of 2.8v, but I really don't want to torch this computer. Any down time on the system means I can't get my MS-DOS and VOODOO fix. Plus it's operating fine with the adapter. In the event I want to mod more systems with K6-IIIs, I would have to go down that route. I almost bought another PL-K6-III but the price just got too high to be worth it.
P.S. NE PC87307, while pretty flexible, can only address 8 GB of storage space on any given device at a time.
