First post, by bruteALEX
Help me guys to run such a program under these OS!!!
I tried to run it with a Dos Box but failed - it's not work
but i get some information why it's not run - "the OS is unsuitable ... unsupported version of MS-DOS (PC-DOS)" - so why i use this DosBox if it write to me such a thing...
Help please I need it... Only Autocad 10
By the way another problem -
Fatall Error Disc(C:) is full - what such is mean - it's really not full
Reply 1 of 9, by eL_PuSHeR
Search the forum before asking repetitive queries...
Replace both AUTOEXEC.NT and CONFIG.NT (in WINDOWS\SYSTEM32 folder) from WINDOWS\REPAIR folder.
Check your system for spyware/malware/viruses.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 9, by bruteALEX
I'm really sorry but
Sorry for my rusty English
I'm a newbie so plesae help me how to find the answer and get the search or link where it was discussed
-It's not so important if windows folder not install on disc C ?
-It's not so important if file system is NTFS ?
Reply 3 of 9, by eL_PuSHeR
No. It shouldn't matter.
Filesystems are transparent for the end user.
Besides, almost everything is virtualised under DOSBox.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 4 of 9, by MiniMax
Rank Moderator
Moderator
bruteALEX, there are (hopefully) 3-4 ways that you might be able to get AutoCAD 10 to run with Windows XP.
The most obvious think to try, is the built-in DOS compatibility in WinXP. The technical term for this the is NTVDM - NT Virtual DOS Machine. The easiest way to see the NTVDM in "action" is to start COMMAND.COM (note: COMMAND.COM - not CMD.EXE). When you start it, you should see a greeting like this:
Microsoft(R) Windows DOS
(C)Copyright Microsoft Corp 1990-2001.
If you do not get this greeting, and instead get an error message that says
The system file is not suitable for running MS-DOS and Microsoft Windows applications
then you need to apply the fix described in this thread.
Once the NTVDM is working correctly, you can try to install AutoCAD from COMMAND.EXE. And if it does not work from COMMAND.COM, then there are various compatibility tweaks you can apply. For more info on this, please read:
http://www.microsoft.com/windowsxp/using/help … /appcompat.mspx
and
http://support.microsoft.com/?kbid=301911
If you can get AutoCAD to work inside NTVDM, that will be the best solution for you, since the program will run really fast.
But if you can not get it to work, more drastic measures are necessary. One posibble solution is to install DOSBox and run AutoCAD inside DOSBox. DOSBox is able to work with many programs that breaks in NTVDM - but it is slow compared to NTVDM.
And finally there is the full-blown emulators: Microsoft Virtual PC 2004 (US$ 130), VMWare Workstation (US$ 200), and Bochs (free). But if you go that route, you also need to add MS-DOS (US$ 20?), IBM PC-DOS, Caldera DOS or FreeDOS (free).
But it is difficult and confusing for both you and us to try solving you problem unless you focus on one of the methods (NTVDM ,DOSBox, Virtual PC, ...). I am not sure if your post here in "DOSBox Games/Apps" means that you have given up on NTVDM already, and want to use DOSBox?
_________________
Reply 6 of 9, by bruteALEX
Maybe the problem with swap file - ...
I've found a program shell room utility which start autocad 10 normally - in 2003 it works but in XP not - there still write that disc is full...
there are a new versions of this program but in 2003 i can't start acad...
    shroom.rar
    20.07 KiB
    193 downloads
    it's shell room utility in 2 versions
Reply 7 of 9, by DosFreak
Thought I had a DOS ver of Autocad but earliest ver I have is R12 for Windows. 🙁
You may want to ask around here: http://discussion.autodesk.com/index.jspa?categoryID=1
From what I've seen from people posts the DOS versions of Autocad are a PITA on today's hardware. Some people have had success with Virtual PC.
Might I suggest Autocad 2004? It's very nice. 😁
Make your games work offline
Reply 8 of 9, by bruteALEX
2 eL_PuSHeR -
In REPAIR folder and in SYSTEM32 folder such a files equal. - I think I don't have any spyware/malware/viruses with assurance 99,9%
It's really work in 2003 but in Xp i have a trouble with running command.com. I will test on my friends in XP.
Yes i want to use Dos Box But my brain is not work good 😀
My Autocad 10 is 1989 year copyright and Yours...
How much it will cost in educational establishment in such not rich country Ukraine? of course it would be so nice but...
Thanks to all i hadthe result - so if i will have some questions I call you 😀
Reply 9 of 9, by MiniMax
Rank Moderator
Moderator
If you can not run COMMAND.COM on your Windows XP system, then something *is* wrong, and you should concentrate on fixing that problem before you try to get AutoCAD 10 to run.
Try copy the AUTOEXEC.NT and CONFIG.NT files from a Windows XP system work and put them on the system that does not work.
_________________
